it's a problem.
Did you prefer listen your room or your speakers ? the acoustics issues are not a spl issue
I was actually not precise in my answer.
First of all, I am fully aware of the importance of the treatment of the room in this type of project.
In 2021 and 2022, I am focusing on the speakers and insulation of my house (windows, walls, etc ...).
The interior renovation and the acoustics of my living room will come after.
Until then, I will benefit from a solution that will not be 100% optimal, but which, like
good French wine
, can only improve over time.
And that I could possibly adapt in other premises if necessary.
Regarding the listening position, I plan a maximum distance of 3 m which I will reduce if necessary.
The critical distance (linked to the frequency range between 200 and 4000 Hz) of the 8351B is of the order of 2.6 m and depends of course on the volume and the acoustics of the room :
https://www.genelec.com/correct-monitors
I think the W371A has an impact on this critical distance. Could the data be communicated by GENELEC ? I believe this question has been asked in a forum before, but I don't remember seeing the answer
Anyway, this is not an absolute requirement .
