Philipp Paul Klose
It seems it is hard to find bad DACs these days... For adding a SPDIF out to my work PC I have bought a Fun Generation UA-202 (Buy here). Only after purchasing it, I have found out that it is also a DAC, ADC and phono preamp.
So, in order to find out how good (or bad) it is, I have made some measurements:
Dynamic Range:
ENOB:
Multitone Spectrum:
FFT:
Jitter Spectrum:
Frequency response (seems more spectecular than it is):
SMPTE Ratio:
THD is general not good, but over frequency there are no surprises:
Conclusion: Despite the fact that the DAC is 16 Bit only (but it seems to accept higher bitrate streams with 24 Bit and 192kHz just fine) it is a competent design without big flaws, but the performance is not really on 2021 level. For a few Euros more, you get way more performance.
SPDIF output works fine. I did not have time to test the Phono in and ADC. Since it is class compliant, it works well with iPadOS, PC and Macs driverless. The sound of the DAC is somewhat clouded and not really upfront. Do I recommend to buy it as a DAC: No.
Dynamic Range:
ENOB:
Multitone Spectrum:
FFT:
Jitter Spectrum:
SMPTE Ratio:
