Feyire
What follows are my frequency response measurements using the miniDSP UMIK-1 and REW on my Pioneer S-3EX speakers in my living room. I hope some of you may find the results of interest.
Additional information:
- All measurements are taken at my listening position on the couch, which is approx 3.2 metres from each speaker
- Targeting 75 dB SPL
- The horizontal separation between the speakers is approx. 265cm
- Both speakers are toed in towards the listening position
- Both speakers are 25cm from the back wall (5cm less than the minimum Pioneer recommend)
- The microphone is at a height of 1 meter from the floor on the couch (this is the height recommended by Pioneer to match up with the tweeter), this is within 10-15cm of my ears at that sitting position
- There is a large and wide glass coffee table between the horizontal center point of the two speakers and the listening position
- The couch is L shaped and the bottom part of the L shape is in very close proximity to the left speaker
When both left and right speakers are measured simultaneously (microphone facing the center point between the two speakers) as shown above, there is a significant null(?) at approx 55Hz.
I'd appreciate any suggestions how to deal with the 55Hz problem and I'd also like to hear any thoughts/comments on the measurements.
Unpleasant observation during my testing: My SMSL SU-8 DAC commits suicide when I do measurements on only 1 channel (specifically the right channel). When it does, it shuts off output mid measurement and I hear a horrible crackle noise. Only way to continue using the right channel after that is to "reset" the device, by playing a stereo signal again. I recall hearing about such a problem in the past, perhaps related to ESS chips not liking it when you do sine sweeps on only 1 channel?
Thanks for your time guys
