Mac mini -> Arcam irDAC -> Roksan integrated amp -> pre-amp out -> sub
That would be great. In time I’m willing to invest in an eq solution at amplifier level so that all sources benefit from it (TV, Blu ray). I’m open for recommendations. But for the time being I’m experimenting at the level of my Mac from which I stream mainly music.do measurements at your listening level and i will have a look at them if you want.
I use Equalizer APO on Windows, I have no idea how you can apply filters on mac.
I will post measurements in the upcoming days, once I’m confident enough about my listening and speaker positions.
Thanks for your suggestions! Indeed my aim is 2.2 stereo only. The SHD is hard to get in EU for a reasonable price unfortunately. Would this be on par with the SHD, as an alternative: https://nadelectronics.com/nl/product/c-658-bluos-streaming-dac/I recommend this:
https://www.minidsp.com/products/dirac-series/ddrc-24
or this if you're fancy:
https://www.minidsp.com/products/streaming-hd-series/shd
they would both remove the need for a DAC and Pre-amp.
Stereo only (2.2), if you're doing or planning to do multichannel then i have other recommendations.
I now see that that C 658 can’t act as a USB DAC which is very unfortunate...Thanks for your suggestions! Indeed my aim is 2.2 stereo only. The SHD is hard to get in EU for a reasonable price unfortunately. Would this be on par with the SHD, as an alternative: https://nadelectronics.com/nl/product/c-658-bluos-streaming-dac/
It’s similar price overhere as SHD but it offers more digital inputs which I’d prefer.
This is the same test measurement but now with 1/24 smoothing:
Do I need to be concerned about not getting above -20db SPL headroom? How could I improve this?
it seems my room acoustics could use some help around 36 Hz and 120 Hz.
