InfiniteJester
- Joined
- Feb 2, 2024
- Messages
- 457
- Likes
- 490
I've been diving deep into the world of convolution reverb for IEMs on Android, and I'm curious about your experiences and preferences. For those unfamiliar, convolution reverb uses impulse responses (IRs) to simulate acoustic spaces or modify the frequency response of audio equipment.
I've been experimenting with various IRs in JamesDSP, an audio app for Android that supports convolution. One IR that's caught my attention is "Phantom Room - Studio" - it adds a subtle sense of space without coloring the sound too much, which I find works well with most IEMs.
Some questions for discussion:
1. What are your go-to IRs for IEMs? Any specific ones that you feel enhance the listening experience?
2. How do you feel convolution affects the perceived soundstage and imaging of IEMs?
3. For those using JamesDSP or similar apps, what settings do you typically use alongside convolution?
4. Have you noticed any differences in how various IEMs respond to convolution? In my experience, Phantom Room works much better with FH9 than with MP145, for example.
5. Any tips for finding high-quality IRs specifically tailored for IEMs?
Looking forward to hearing your thoughts and recommendations!
Here is the .irs that I'm using, for if you want to try it:
