Pancreas
- Joined
- Nov 2, 2022
- Messages
- 617
- Likes
- 170
- Thread Starter
- #21
I have Genelec's with a Topping D30 pro. Everything is set to turn on with signal and off without. I have no pops, thuds, or noises.
So what do you think is the problem then? Maybe your DAC has something to prevent the pops? What do you mean everything is set to turn on with signal and off without, you mean using the Genelec standy by feature?
Thank you.
I read this review of Scarlett on amazon, it explains my issue
There's also a problem with auditable noise when idle, during boot-up and even randomly when playing audio. Turning on the PC and hearing an audible pop coming from the Focusrite quickly reminds me just how quiet the Steinberg was. I am going to guess they used a capacitor-coupled output stage to save money, instead of an AB class circuit. Capacitor coupled outputs are a sure way to introduce an annoying DC pulse into the audio stream when power is applied to the circuit. It may have been acceptable back in the day when older audio equipment had turn-on pops and often used relays at the output stage to somewhat compensate. But in todays world, it's easily solved with a $2 class-AB operational amplifier IC. Maybe it's time for Fucusrite engineers to peek inside Steinberg's circuit goodies.
