Genelec G Three B and Genelec 8030C, not the same speaker. A measured (but somehow informal) comparison.
Miguelón
Vigo (Galicia, Spain)
Genelec offers two options of its 5 inch popular entry level active speakers: a professional version called 8030C and a second dedicated to home setups named G Three (which actually has been upgraded to “B” since its first iteration).
Is a common question around potential customers why we should buy one or another depending on our sources or even aesthetic choices. Actually is difficult to have precise data from Genelec about which version of G Three and 8030 matches, or at least I found confusing dates on their website, including the japanese one that shows exact same measurements for G Three B and 8030C.
Actually I have both speakers at home, a little long history, and I’m in a good position to offer some answers to questions of members and info measured by WiiM Ultra room correction app, to help decide future purchases.
Measurements carefully taken in same positions, room temperature, SPL and distribution of living room elements to minimize error and subjective impression.
Source was WiiM Ultra connected to Focusrite Scarlett 2i2 4th generation (G Three has RCA connection but avoided this path to be interferences free) by usb A to usb C 2.0 cable.
Subjective impression was surprisingly different, in the sense I expected to make a stereo couple once correcting sensitivity at the source (G Three is around 10 dB @ 1V less sensitive in its highest configuration).
Once equalizing main modes and reflections I struggle to make G Three as clean as 8030C sounds, according to Genelec curves it seems that G Three has the slight more 100 to 200 Hz response and less controlled low region of the 8030B version. Throwing sine signals at 50, 80 and 100 Hz G Three port give a noticeable “bzzzz” at less power, of course 8030 resonates too but holds clean 6 dB more.
This is G Three at my living room with 3 main bumps (P are the typical room mode, S is augmented recording close to horizontal surfaces and T got me crazy till I discovered was produced by my TV screen reflection). Alterations from the expected curve go uniformly less pronounced as frequency goes up, ignoring the 10k and over region (probably a mic issue).
This are my final filters, I averaged different positions to obtain a higher listening area, TV screen reflections were on the 6 dB from the right side and 0 dB from the left, finally -4 dB at 700 Hz were chosen.
G Three measurements were very similar, slightly less sticked to target curve and showing less diminishing alteration with frequency, also less energy under 100 Hz as 8030 B version has.
Filters show less energy on the low region (2 dB less) but more on the 700 Hz response (I should lower by -6.5 dB).
My general impression is that G Three has more to do with the B version of 8030 active monitor (Genelec doesn’t mention specifically that is same internals than 8030 C and show wrong graphics in G Three B specs, with older G Three A recording file. In the japanese website they show equal measurements than 8030C, perfectly point by point, but frequency accuracy was 2.5 dB instead of 2.0 dB at the technical specs).
If you have an audio interface, a preamp or a DAC with XLR outputs I believe is a better idea to go to 8030C, notice that (this is subjective) it will sounds better at highest sensitivity so you will end up on the lowest region of the source power. My Focusrite attenuator behaves absolutely clean but tuning down the gain knob on the 8030C was a bad idea. Maybe Genelec has saved some money on the attenuator, they even specify at the website that 8030C sounds better at -6dB sensitivity.
Connecting G three B with a RCA to XLR cable was also a bad idea, here I think was the cable (J & D audio, please don’t buy it). RCA to RCA showed less distortion (again subjective, but was quite noticeable).
My personal impression is that WiiM Ultra alone with G Three RCA connected is a good option if you’re interference free, is simple and one has no issues with adaptor cables design. If you need to avoid interferences or loops better go to 8030C and an external DAC with balanced outputs. I’m waiting to Monoprice RCA to XLR dual wire cable, which should work well, so I will update to the WiiM RCA to Genelec XLR path.
I tried to do my best with modest equipment, I had a very good time measuring here and there, changing place of tables and chairs, and learning a little bit of my room and my speakers.
My final choice is 8030C, because I have a balanced DAC with a well made attenuator (at 12 or 1 o’clock position gives me room to handle digital volume on the WiiM remote with good accuracy and keeping 8030C in its by default tremendous 106 dB @ 1V sensitivity, why they build amplifiers so sensibly??).
G Three B is around 200€ more expensive than 8030C depending on dealers, so double argument to buy the latest. 400€ cheaper for the pair, one can get a Topping balanced DAC or save some cash for the 7050 subwoofer or anything else).
Sadly I would prefer the simplicity of G Three B with WiiM Ultra and F Two subwoofer (which I also bought and returned) but is a 900€ more expensive set than 8030C + 7050B and poorer quality.
A personal reflexion is that one should trust more on pro lines despite a little extra work to setting up, quality / price ration may be better in general.
Have you talked to Genelec about any differences between these models?
Yes, they said me that Genelec Three B is equal to Genelec 8030 but they didn’t mention which one. I’m waiting for an answer by email of the technical support, but my measurements show that is not the same.
In general we can expect some variation between speakers of the same model, but I owned 8030 C and two G Threes B, and between each pair they match well, not mixing them.
At first I thought was just sensitivity, but now I can’t control very well balance between 2 channels (in mono of course) and is easy to hear and measure the difference.
Is not enormous, as is not huge the difference between 8030C and 8030B. But the extra money of just an RCA connection more in G Threes supposing are the same and I’m wrong is totally unjustified: as I mentioned for 400€ the pair you can perfectly buy a DAC.
Interesting comparison. I have to say, I find the large price difference in your region to be a bit strange. Here in the US, the G Three and 8030C both sell for the same price ($695 per speaker via online retailers) so cost is not really a factor.
I ended up going with the G Threes for my home system simply because I needed RCA inputs and preferred the color options available, but if there was a $200 price difference between the two, I probably would have just gotten the 8030Cs and saved myself the money.
In any case, I couldn't be happier with the G Threes in my small/medium size room. They sound absolutely fantastic - especially when paired with subs. Noticeably better than the (quite good) Focal floorstanding speakers that they replaced.
And given that they eliminate the need for external amplifiers, they also represent quite good value, IMO.
Both are good monitors, the difference is quite tiny. 8030C goes a bit lower and is better in directionality (I measured at 20 and 40 degrees of axis this morning) and slightly flatter.
I’m now totally sure that is the same as 8030 B which was a very good monitor.
In Spain, G Three B is impossible to buy, and dealer that Genelec recommended was Finnish Design that sells quite expensive decoration objects: is funny to know that Genelec design is mainly detested in ASR but appreciated as a decorative object in some circles :)
Which subwoofer you have?
Personally, I really like the way the Genelecs look - I find the curved profile to be much more attractive and interesting than a plain rectangular box.
For subwoofer, I'm using an SVS SB-1000 Pro in my main listening system. Both the subwoofer and G-Threes are connected via a Denon X3700 AVR which handles the bass management.
I also have a second pair of G-threes in my studio, which are connected to a Kali Audio WS 6.2 subwoofer. This particular subwoofer is designed for active studio monitors and doesn't require any external bass management. You simply route the directly signal from your DAC to the subwoofer, and the subwoofer has a pair of balanced outputs which are then connect to the monitors. The subwoofer plays all the frequencies from 80Hz and below and sends everything above 80Hz to the monitors.
Both sound really good.
Is the same system as Genelec 7050, which I intended to add to my 8030s. Is also adequate to little rooms, I can use internal crossovers or WiiM Ultra sub output.
I know SVS SB-1000 pro, happy to read that works well with Genelecs G Threes, I should consider it instead 7050 perhaps.
@Miguelón Did you happen to hear back from Genelec which 8030 are they matching?
Yes, and I verified at home what’s going on…
Genelec said that G Three B and 8030C are “acoustically identical”, only change is sensitivity.
I was comparing both by matching 8030C at +4 dB in the gain knob, which changes tonality quite audibly.
Then as the technician suggested, I let 8030C at -6 dB, the by default level and just compare them by balance regulation on my WiiM (-73 on -100 to 100 left to right balance) and voilà, they coupled perfectly.
So are identical, but just by having a hotter source 10 dB up I prefer keeping the G Three, lower noise.
The technician suggested to not alter by default levels and use an analogue attenuator to match voltage output on the preamp (or attenuator) to voltage input on the Genelec.
Thanks a lot for confirming. I'd probably also reach out to Genelec support regarding some queries I have before purchasing some speakers for myself since I've only ever heard good things about them.
They are so gentle with customers, Finland is a lovely country concerning politeness.
@Miguelón - so for a living room system for general music listening (no sweet spot). Would you recommend the G three with a third party sub and a Wiim Ultra? From what I've understood, using Gen subs with Gen monitors that are sam enabled via GLM provides excellent integration, would this still be the better option considering the use case.
I feel this should be added as an update disclaimer at the top of the opening opening post. Would you agree?
I cannot tell you, I never had GLM compatible speakers.
All can I say is that G Three is a great value for the money, and WiiM integrates perfectly with them in sensitivity so that you don’t have to use any preamp or attenuator.
I suppose GLM a great tool for professionals, which won’t move from sweet spot and flat FQ curve is a must.
Since most people tell wonderful results I guess 7350 or 7360 plus 8331 will have better in room response, but also prepare 700-800€ more including the GLM kit
Yesssss…. nope, I changed my first impression since I received the second unit of G Three.
Tonality is the same, as expected, when keeping 8030C at max sensitivity, but the later has more noise by far.
Having received a (well deserved) email compliant by Thomann because abuse of returning program, I realized that G Three is an improved version of 8030C in electronic sense.
Let me explain, I think the gain knob is the problem when you have to content a slightly obsessive audiophile (I think we’re at least half of members here). I guess that for a professional worker having more noise is irrelevant if FQ curve is preserved, and for 600€ the unit they can’t add an ultra clean attenuator.
I tried all possible DAC-attenuator-8030C/ G Three permutations, and the one is less noisy and more beautifully (sorry for subjective terminology) is G Three - WiiM Ultra RCA with no voltage reduction on the latest.
So my premise was wrong, possibly because evaluating only one unit of G Three, my vote goes to G Three for homes unless same acoustical properties.
I've read through this thread and, in conclusion, I'd like to understand what the difference is between 8030 and G3 in sound quality and senstivity. In layman's terms I'd appreciate to have an advice about the behavior in different scenarios:
1) Both used with xlr balanced connection through an audio interface: are they exactly the same, also in terms of "volume knob" on the interface?
2) Both used unbalanced - G3 with rca to rca and 8030 using an adapter cable and both driven by a stereo hifi preamp in order to set the volume ( and switch between multiple inputs like turntable, CD player, PC etc.). I understand that G3 is built with that in mind, anyway I'd like to know if the sound level is exactly the same or not.
In conclusion it would be interesting for me to figure out wether both models may give the same results in the above listed situations or there will be any drawback with one or another in terms of spl, frequency response, hiss etc.
My question are not just theoretical, but as I'm seeing some deals for both of them used I'd just like to make the right choice in case I take the decision of buying a pair .Thank you for all your answers.
SPL is the same on both devices.
G Three has 10 dB less sensitivity which allows you to increase 10 dBu the signal to obtain same SPL.
Having them side by side during 3 weeks, G Three sounds more clean once setting 8030C input gain + 4 dB. This is a subjective affirmation but to me and my girlfriend the difference was notorious. I attribute the difference to 2 possible causes: an increase of 10 dB in my setup output behaves better, or the attenuator in the Genelec 8030C input gain knob introduces audible noise.
In G Three you have the option to turn off the light diode.
Bad side: if you’re going to Genelecs subwoofers of the 70xx or other pro line, sensitivity of 8030C matches 7040, 7050…
When using G Three you should reduce 10 dB on the input of the subwoofer.
Apart from this minor differences, are acoustically identical.
Thanks a lot. So the standard sensitivity on G3 ( without lowering 10 db) is equivalent to +4 on 8030? I understand that both can be connected to an audio interface or to a hifi preamp; my impression was that the rotary knob on the 8030 would allow more "fine tuning" given the multiple options between -6 and +6. On the other hand, if the hiss issue is lower on g3 they would probably be a better choice regardless of pro or consumer connections used, unless the case being your particular 8030 more hissy, for any reason.
Not the case of my unit, had a pair and also 8020D: they are all more noisy than G Seriers. Is noticeably when comparing side by side, otherwise they sound very similar.
Yes, +4 dB setting in 8030C equals by default G Three sensitive, and yes the gain input can be used either to fine tune sensitivity inter-speakers or adjust to different gain inputs.
The reason I don’t need it is that I can fine tune the channels on my DAC-DSP, and almost all setups require +6 dB or + 4 dB to reduce noise: Genelec chose a too high sensitivity on their monitors.
With the G Three you have a switch which lows down another 10 dB the input gain, can be useful in XLR case because many modern DACs goes to > 14 dBu output in balanced outputs (XLR or TRS).
Both speakers can be connected to interfaces or comercial DACs, I have also a Focusrite Scarlett which use with G Three by XLR-TRS or the WiiM Ultra by RCA.
Thanks a lot, great help! Just one last thing, I case I take the deal I've seen. How to check wether a used G3 is the A or the B model? If the serial number says G3BW etc. and the date is 5/2017 it means it's the B version?
