EQ settings for Focal Eligia from oratory1990
Joramun
staticV3
Three things:
1. Go into Peace's Settings->Sizes and Amounts->Snap gain and set that to 0.1dB
This will allow you to set the the gain for each filter properly.
2. All Low shelf and High shelf filters in Peace must be set to the the Q version to match the response to what oratory intended;
3. Your Pre amp is set a bit too high. -6.1dB is required, I'd set it to -6.5 for peace of mind.
John_Dikeman
Just curious what others thought of this EQ. For me it really squashes the sound field.
Any suggestions for otherEQs?
EDIT
My mistake, for some reason it switched to mono. Not sure how that happened.
At any rate, I'm still interested in other EQ recommendations.
