Too much kangaroo juice I imagine.I can't listen to some classical music. The multitude of instruments/sections, musical parts, and their interaction presents a cacophony of sound that is overbearing.
IMD?
IMD?
Sorry, I thought it was obvious? Hard to give an answer that will satisfy you, but for a start, none of the instruments are running through a Marshall stack (although that would be interesting lol).Why?
Sorry but the problem is you generalize way too much, a usual failing of classical music fans derision of the importance of anything else.Sorry, I thought it was obvious? Hard to give an answer that will satisfy you, but for a start, none of the instruments are running through a Marshall stack (although that would be interesting lol).
IMD?
Classical Music demands a high DR of at least 16dB (maybe 14dB absolute minimum). If you compress it, the very quiet passages become equal to the very loud passages, which is not true to the style of the music. The best way to listen to Classical Music is either with headphones &/or a perfectly settup & quiet listening room. I cannot imagine anyone trying to listen to Classical Music in their car, as it's just not a workable environment for the style of music (I myself do not listen to classical music, but I have mixed & mastered many recordings).
EDIT: You also have to remember that the more compression or limiting you use, the more distortion you're adding. The unwanted distortion might be fine for Rock, but it's really a thing to avoid in Classical Music. This is also one of the main reason that so-called Hi-Res recordings sound better. It has nothing to do with the higher available frequencies that you can't hear anyway, it's to do with how the files are processed (or more to the point, not processed).
99.999%At 16:00 the level drops 30dB which is more than the amplitude of 99% of the 3500 rock-pop songs in my music library.
Agreed. There could be a lot of reasons for that, depends how it was recorded ect ect
...and usually it's the fault of the person that mixed it. You can have a good or bad mix with any genre of music.Nope, loudness and musical information overload/interaction. Usually symphonies and hyperactive composers. Occasionally Frank Zappa. View attachment 59412
And shockingly Jethro Tull’s Heavy Horses. Sadly one of the group’s worst and I’m a big Tull fan.Nope, loudness and musical information overload/interaction. Usually symphonies and hyperactive composers. Occasionally Frank Zappa. View attachment 59412
Does it also happen when you listen live? (trying to exclude you as cause)
I don't attend live classical performances.
As others are happy with the classical music I find problematical I think it is me. Maybe not just me, though.
Do you know if it's particular of complex classical music or if it also happens with other genres?
Maybe some of Beirut's music, or Fanfare Ciocărlia's, may also trigger an identical response for its strong and lound brass content and multiple instruments. Or some big band jazz?
If you don't listen to any of this live your system/roomcould also be playing a part.
Because most pop music is deliberately distorted to start with. Of course, the reality is what we really want is for X to = X. But some folks, cough, cough, vinyl supremacists, cough, really do like the pre-distortion of "classic" LP playback.Why?
Seeing one of your later posts, I've been involved in enough recording to be able to observe how common various post production tools are used to compress, eq or otherwise alter the raw materials of a recording. This is not a bad thing, but this is not "The Absolute Sound". Honestly, microphones all "distort" the sound, and many recording engineers, musicians and producers deliberately seek out the of compression of analog tape.
Distortion is used as a recording/mastering tool, but distortion is still distortion whether it's intended or not. Generally analogue distortion is good, digital distortion is bad. Scientifically, your ears enjoy the distortion produced by a turntable, but hates the jitter produced by digital sources.This is just the same classical/acoustic bias again.
Those effects aren't distortion because they part of the intended sound. By your logic, the overtones on a purely acoustic instrument are "distortion" as well.
