John Darko has made a review of both the transport and the DAC yesterday I think... I watched it, but didn't pay too much attention to the DAC part; maybe you want to have a look at it.
Hi Does any one allready commpared the Shanling EH3 dac/headphone amp and compared it to the topping D90. I own the topping and just bought the shanling ET3 CDtransport. The EH3 could be a nice replacement for the topping?`
I think your correct only problem is I would like the I2S connection. I allready use the usb input. And what i read with a standard hdmi cable the I2S will not work between the Topping and the ET3. But I just bought a cheap 3 euro solderless hdmi connector and will try to make my own i2s cable.I've got three Topping D90s and you won't hear anything better. If it's got features or connectivity you want, but don't expect it to sound any better. We've really hit a wall with this stuff, even high end amplifiers are sounding the same since they're so transparent with high SINAD scores.
I'm waiting for your results!I think your correct only problem is I would like the I2S connection. I allready usb the usb input. And what i read with a standard hdmi cable the I2S will not work between the Topping and the ET3. But I just bought a cheap 3 euro solderless hdmi connector and will try to make my own i2s cable.
Let me guess: it all sounded very good and was great value for money?John Darko has made a review of both the transport and the DAC yesterday I think... I watched it, but didn't pay too much attention to the DAC part; maybe you want to have a look at it.
As I said, I don't know. I was just curious about the transport; the looks of it also.Let me guess: it all sounded very good and was great value for money?
The app cannot see the ET3, so you can wake it up from stand-by mode, or everything works fine from this point of view, but just the streaming services do not work until you power off->on?Could get it to work for todays in row. After I put in to standby, I needed to do a hard off on to get streaming working. The app could not find the ET3.
Then it looks like the unit needs some time to properly reconnect to the LAN after having been on stand-by. It's all fine IMO.Just tested. Wake up player from standby (using remote) Waited for 10 minutes or so and this time streaming worked fine. The app saw the ET3 and was able to stream music to it. So it some times works after waking up from standby.
Can you explain a bit on how is designed that streaming system you are using that involves de ET3? Which is the management application and what source/s you are using?Small update today I received my cutom I2S cable from https://nl.aliexpress.com/item/1005005848661432.html
Works great. Not sure if I hear any difference between AES or I2S. Maybe some more clarity. But could also be a little bit difference in volume. Will also play a bit with upsampling.
For CD playback the ET3 works great, for streaming is also sounds great but. It is a pain to get streaming working. Could get it to work for todays in row. After I put in to standby, I needed to do a hard off on to get streaming working. The app could not find the ET3.
Which HTPC you have that runs Foobar? I want to make my media players run Foobar for streaming music from my PC, but I couldn't till now.Mainly I use the Et3 as a cd transport, so just playing CD's. For streaming I have only used it for local playback from attached ssd drive(usb adapter) and some streaming using store music on HTPC running Foobar with a dlna plugin in with expose my local library. Using the eddict app I can then search through the library.
This less conveniënt then just using my htpc and foobar for playing music.
For now I only use it for direct CD playback. CD playback using I2S was my main reason off buying the player.
Now I realize that you were talking about a PC that seems to be used as HT. Not a HT receiver running Android. None of my Android media devices that I use as media manager, with Kodi, accepts Foobar.Which HTPC you have that runs Foobar? I want to make my media players run Foobar for streaming music from my PC, but I couldn't till now.
