Hi,
Slightly confused and nothing is clear.
After some research I discovered the SMSL Sanskrit 10th MKII worked noticebaly better if you added an aux power supply, and IMO, it is noticeable.
So using USB in and an aux power supply - but what if only using optical in? As in I don't have a USB audio connection to the device
I am not using the USB in, so, I am confused, in general.
EDIT: Actually can someone recommend a power supply because I have no idea what I'm doing... Currently it's plugged into a USB wall outlet - no idea if this is appropriate. It doesn't matter how many times I read the manual note (and it has been many) I simply don't understand it.
