Noodles
So, i thought i'd start this to see people's opinions on dirty usb signal issues.
I had a few run-ins with several dacs over the past years where my PC hardware has not really changed. I've had a few SMSL dacs, some topping dacs and now i got the USB converter (d10s) and an RME ADI-2 DAC.
I've had the same cables and i do not recall having changed something in the mean time that could affect what i am about to describe.
I got a dirty USB
--Not that dirty, stop what you are thinking.
So i've suspected this for a while but i can confirm it now - the USB signal through all the motherboard's controllers/ports is quite dirty. I have either some coil whine bleeding into the power or unshielded traces, idk what specifically.
Plugged into my RME i have absolutely no issues whatsoever. The previous Topping Dx7 pro also had 0 problems.
I got the d10s today and what do you know - there it goes - the whine is back.
Anyone have any suggestions on how i can alleviate this (not going through a powered hub) ?
I got a dirty USB
