Katji
- Joined
- Sep 26, 2017
- Messages
- 2,990
- Likes
- 2,273
Then you check, you check the package that is advertised, you send message to the supplier asking about the SMPS. "might even be" !You check, you ask, you find out! Otherwise you assume the same!power = wattage
Same. The circuit/boards are the same.
[quote,how loud they can play and power supply,adapter
Some amps comes with a 24 v power supply and some has a 32 volt power supply, there might even be one that comes with 19 volt instead of 24 or 32 instead of a 24 volt power supply
