Desktop "rack"....
EJ3
James Island, SC
Wife Acceptance Factor plant add-on to easily integrate new speakers into the main room !
Avoid watering (my wife likes plants but has a black thumb, give her a plant & it is going to die). Use a silk plant. Silk ivy is good to hide wiring too, according to my wife. This is when I asked her what happened to the wiring to the air conditioner. OK, it is now within a strand of "faux" ivy. I'm ok with it, she doesn't bother me about my wires once they've been 'ivyed". Then I get to listen in peace.
anotherhobby
Topping Acrylic Rack in use.
Hot tip for less than $7: Speaker Isolation Spike Protectors
TheBatsEar
Germany
I see a future of vast amounts of dusting with this type setup.
Is there any other future with any other setup? If so, i want to know.
EJ3
James Island, SC
Is there any other future with any other setup? Is so, i want to know.
Something with ventilation, air filters, clear or smoked doors. When not in use, it is not collecting much dust between it's feet or on it's case. Of course, from time to time there will be some dusting (and some pulling the cases apart to use clean, blowing air like with a computer tower (or even a laptop). But not near as much as with things left on open shelves. The same reason that my TT has an acrylic cover. When it is not in immediate use, it is covered.
_thelaughingman
quimbo
That's some serious Schitt you've got.
End game for my desktop setup.
I can choose 6 sources for my BiFrost:
USB - Allo UsBridge Sig Streamer
Optical - Cowan Plenue Mk II
4 Coaxial choices using 4x1 SPDIF Digital Audio Switcher
1 - Computer headphone out (for videos, etc) using Analog to Digital Audio Converter
2 - Shanling PCD300B CD Transport
3 - Phone / Tablet (for Podcasts) using Douk Audio USB Converter
4 - Fiio X7 Dap
Total Flexibility. I currently use JBL 308P MKII Monitors, i may upgrade those
Multiple headphone choices including AKG 240 Sextett, Sennheiser 250 Linear, Sennheiser 540 Ref II, DCA Aeon 2 Closed, AKG 550, BeyerDynamic 770
Multiple IEM choices
we have come so far since my introduction using an AM radio and a single ear bud in the mid 60s
JeremyFife
Scotland
Or you can assemble two stands like these from amazon with double tape or some glue
https://www.amazon.com/FITUEYES-Computer-Monitor-Component-DT103803GC/dp/B079FPT1VX/
  • Color: Transparent
  • Material: Glass
  • Size: 15.2" x 9.4" x 3.0"
Second that - neat (cheap), extendable and little sticky pads keeps it stable (DSP and Zen are offset for the cables). Room to add another tier for a headphone amp later
Cincyret
Cincinnati Ohio
Ok...Here's my rack:
2 - 6" x 12" Glass shelves, 8 - 2" red standoffs, 4 - sorbothane+Felt feet, UV Glue - 7" to top of amp (so 12" x 6" x 7")
From bottom: Minidsp Flex (balanced), Topping EX5, Topping PA5
John
billymac
+1 for the Topping acrylic rack. Just received mine (took about 2 weeks from Apos). Very pleased with it.
What should I buy to put on the top rack?!
