somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 3,682
- Likes
- 2,962
I see a future of vast amounts of dusting with this type setup.If you're willing to do wall mount monoprice has some options like this: https://www.monoprice.com/product?p_id=10480
Avoid watering (my wife likes plants but has a black thumb, give her a plant & it is going to die). Use a silk plant. Silk ivy is good to hide wiring too, according to my wife. This is when I asked her what happened to the wiring to the air conditioner. OK, it is now within a strand of "faux" ivy. I'm ok with it, she doesn't bother me about my wires once they've been 'ivyed". Then I get to listen in peace.Wife Acceptance Factor plant add-on to easily integrate new speakers into the main room !
Topping Acrylic Rack in use.
Is there any other future with any other setup? If so, i want to know.I see a future of vast amounts of dusting with this type setup.
Something with ventilation, air filters, clear or smoked doors. When not in use, it is not collecting much dust between it's feet or on it's case. Of course, from time to time there will be some dusting (and some pulling the cases apart to use clean, blowing air like with a computer tower (or even a laptop). But not near as much as with things left on open shelves. The same reason that my TT has an acrylic cover. When it is not in immediate use, it is covered.Is there any other future with any other setup? Is so, i want to know.
Lifters... ha ha ha!I like the lifters on your keyboard cable. Do they provide any audible benefit?
Thank you for this, I ordered option B on 2/21, they arrived today 3/11. These are perfect for my Schiit BiFrost, Lokius, Lyr3 stack
That's some serious Schitt you've got.
End game for my desktop setup.That's some serious Schitt you've got.
Looks like the Flex is too big to sit on the top shelf?
Correct, the Flex does not fit the Topping rack.Looks like the Flex is to big to suit on the top shelf?
Second that - neat (cheap), extendable and little sticky pads keeps it stable (DSP and Zen are offset for the cables). Room to add another tier for a headphone amp laterOr you can assemble two stands like these from amazon with double tape or some glue
https://www.amazon.com/FITUEYES-Computer-Monitor-Component-DT103803GC/dp/B079FPT1VX/
- Color: Transparent
- Material: Glass
- Size: 15.2" x 9.4" x 3.0"
What should I buy to put on the top rack?!
