One suspects the difference you heard is measurable, but the “studio standards of the time”, and conceivably today, did not include those measurements.that every is measurable and determinable.
The P3500S has a fan that only kicks in above 50 °C, right? Best to just leave it as is -it's a fairly sealed enclosure. That said, if you're not pushing it hard, it might not matter, but it is a Class A/B (or EEEngine) with toroidal transformer so heat is best expelled.I'd always been a bit skeptical, but I think the tipping point for me was when my 22kg class AB/A monster of an amplifier finally died. Sent it in for repairs, bought a cheap B-stock pro amp just so I could still have sound, and ended up barely hearing any difference. Subjectively it did sound a bit harsher at higher volumes, but I might've just been running it a bit too hard there... and it was also a tenth of the price of the big amp!
I eventually replaced the big amp with a Yamaha P3500S, which sounded identical but was way more usable, and cheaper to boot. Shame that the common internet "wisdom" of pro gear sounding "boring and emotionless" turned me off on that stuff before, but thankfully the amp died before I got too deep down the rabbit hole.
Oh yeah, and that cheap temporary amplifier? It's still kicking 10 years later! I disconnected its fan right after I first got it, and have been abusing it in all sorts of side setups for all those years... and it still runs great. Funny how that works. (it's a JB Systems 200.2 if anyone's curious)
Every reasonable audiophile is someone who recognizes and promotes the importance of measurements, research and room acoustics.
Describe your decisive experience that completely changed your view of audiophilia with a comment.
Nah, by "cheap temporary amplifier" I meant the JB Systems that I bought to hold me over during repairs. The Yamaha came later, and I never modified that -- have yet to hear the fan come on!The P3500S has a fan that only kicks in above 50 °C, right? Best to just leave it as is -it's a fairly sealed enclosure. That said, if you're not pushing it hard, it might not matter, but it is a Class A/B (or EEEngine) with toroidal transformer so heat is best expelled.
Just a heads up.
The A/B test wasn’t in an anechoic chamber. Give. The designs, the off-axis response couldn’t be the same, no compression tests?….i mean, you know all this.In all three cases the developers themselves independently claimed it is not measurable with standard models. In two of the cases, in which pro-audio developers were the ones to claim that, I had the opportunity to take part in A/B comparison tests to confirm this.
One I remember in detail, it was a listening comparison of two identical midrange drivers, one in a closed-box design, one in a cardioid/semi-open baffle concept. Both drivers were calibrated to on-axis response showing a deviation of less than 0.2dB from each other over the whole band and as the comparison took place in a true anechoic chamber, all standard measurements and models would have suggested no audible difference. In contrary, the audible difference was huge, spanning over the complete lowest octave of the midrange driver adding some kind of muddled, boosted, resonating lower midrange to the CB unit while the cardioid showed leaner timbre and increased midrange transparency.
You should have seen the eyes of the lab director who afterwards spent more than 2 hours to over and over measure the two, finding no FR difference in whatever angle of the sweet-spot being used.
I agree, and of course there is a lot of unnecessary, overpriced stuff around. Nevertheless I have the feeling that with the right explanation and impressive demo, you can get many audiophiles to rethinking their beliefs, particularly when it comes to adopting a speaker to the room and doing room correction.
In contrary, I miss the willingness of the self-proclaimed objectivist fraction to accept audible phenomena and criteria of evaluating sound quality which are not determinable by standard models. I oftentimes think they could be learning from some crazy audiophiles as much as the latter might learn from them.
Longer resonance and reflections would show up in standard (today) speaker tests. Was it just driver FR?Yes, they were.
Off-axis response was naturally very different, but that should not have played a role in the anechoic chamber. Compression was tested in form of FR measurements at different levels. Of course both designs were not identical, there are multiple explanations possible why they sounded so overly different: longer sustain in the resonance area of the CB driver, reflections in the cabinet coming out through the diaphragm, slight deviations over different angles within the listening window and many more. The point is the experiment showed how limited our standard models of measuring loudspeakers are, and it was partly shaking worldviews of some lab engineers who had previously thought that no tonal differences are possible if FR is identical.
And given the importance of the result was the test replicated in blind ABX?
It was your suggestion, and the cabinet is certainly in the chamber. Perhaps I’m missing something, but why exactly wouldn’t these phenomena show up in standard FR and waterfall?reflections in the cabinet coming out through the diaphragm,
The fact that nobody did just makes me suspicious that they felt it either wasn’t replicable or was easily explainable from known, measurable quantities.
I have done a lot of blind tests over the years with people who claim to be able to hear all sorts of things, changed the system in ways that they claim are 'shockingly audible', yet they can't detect them by ear alone. I think, based on over 40y of being around 'philes (and a lot of musos who can be even worse) that most of them are FOS.Describe your decisive experience that completely changed your view of audiophilia with a comment.
Which (measurement) method would be able to show the difference?A FR sweep is just the cumulative sound power across a given frequency range and test duration. It's the sum of all the powers of all the frequencies across the entire duration.
But when we listen we aren't averaging across the same duration, and our hearing is none linear.
You can play a pair of sweeps with identical frequency response but one shifts from sine to triangle wave and the other is pure sine wave. They measure the same but sound different. The nonelinearities of two diffetent speaker cabs could give the same raw FR but sound different by many similar mechanisms.
They average out the same over time, but temporary are quite different at any instant.
