Hausmeister
- Joined
- Jan 8, 2024
- Messages
- 14
- Likes
- 4
Hi all,
thanx for providing these interesting measurements, I just discovered this page! I have a Sennheiser HD598SE and tried to use the EQ settings provided here
I don't quite understand the PEQ settings when comparing with the provided graph and the data provided in the second post of that thread. There is a low shelf with 6dB which should make the EQ curve go to +6 when f -> 0. However, the graph shows a value around 4 dB. I suppose the difference stems from the total gain indicated by the yellow line which is around -2dB (maybe -2.1?)
However, the next post (by user @sweetchaos) indicates a preamp setting of -7.1dB. Maybe it should be -2.1dB??
Also, which definition for Q is used here? Is this Q the same as the "RBJ Q" in REW (see last table on that page)?
Maybe these settings are explained somewhere, I have searched but could not find any info, sorry if this is a FAQ.
