restorer-john
A redesigned X.O., wiring and tube connectors will lift performance to unseen heights
My Timewindow 1as actually had a type of tube connector for the bananas IIRC. Seriously.
Internet pic
See if you can find Sorbus torminalis as a wood for the job (cabinets in generally) and of course not for the looks of it (but for density and properties).Yes, I agree. What would be modern, would be some of that light bleached ash style timber end caps and that white/grey/cream woven fabric like Ikea use on everything. Like this:
Classic Peter Aczel and The Audio Critic!The last paragraph of that commentary above on the improved timewindow is quite remarkable (in a good way).
The fact that the radiation geometry of the CX-Series is more like that of a ”conventional” cardioid pattern speaker than the Time Windows and early TimeFrames probably makes them a better choice if you’re going to use them in surround system (so I have found.) I have modified my Generation-1 “Time Windows (Improved)” pair to reduce the output of the “outboard” drivers by 3dB in keeping with what DCM said, in reference to the characteristics of newer versions of the Time Window, was preferable for tighter imaging at the expense of some soundstage width, so I can used them more successfully in my Dolby Atmos system. And they were right. As an added bonus, the CX-17, 27 and 31 use a coaxial driver arrangement (with the very sweet Visaton or Vifa tweeter) which further improves imaging coherence. So, I wouldn’t bat an eye about going with them unless you’re really jonesing for the original Time Window magic that comes from spreading all that mid to high-frequency joy toward the side walls and around the room.While looking into these I came across a really nice pair of CX-27s for next to nothing. They sound awfully good so I am in something of a quandary.
This speaker is the only commercial speaker that ever was able to recreate an acoustical square wave in a room. We did tests that proved the speaker had an essential zero-phase delay of all harmonics from 20 to 20khz hence, capable of forming an acoustical square wave about three meters in front of a pair spaced two meters apart.
As I recall - Quad made that claim with the ESL63?I remember all the talk about phase being excellent with the Timewindows themselves. With the two pairs I had, 1 and 1as, I found that to be not true at all.
Being as you have a pair of Model ones (a different speaker of course), can you demonstrate the method and show this square wave? And show us a few pics of this interesting speaker you have.
Cheers.
We took pictures of the osciloscope trace and used it on one of the first Time Window brochures.
You are totally correct there.As I recall - Quad made that claim with the ESL63?
I've downloaded the pdf for my reading enjoyment. I'm also enjoying the back-and-forth between participants. It's telling a story, and I hope there's more to tell. I'll throw in if there's any interest; as I mentioned above, I own an original pair. I haven't modified them in any way. Assuming they're in good working order, and anyone wants to bother, I'll allow them to be tested here in Madison Wisconsin. I read that the UW School of Engineering has an anechoic chamber. Supposing - and this is a big supposition - that they'd allow us to perform tests there, I'll allow my Time Window loudspeakers to be evaluated there. Stipulation: my loudspeakers have to be returned to me in good working order.The TWs were extensively reviewed by the highly respected Louis Challis in ETI, January 1981 here in Australia.
I've made a PDF if anyone is interested (attached)
These no doubt were the units 'featuring' the horrible and cheap Philips plastic dome tweeter which they carried into the 1a before upgrading the 1a to the Vifa D19 tweeters.
