Damaged KEF LS60W Woofers - Aesthetic or Measurable?
Danaxus
Greece
Please look away if a photo can cause you physical pain.
As to the how: toddler. And on that note, anyone here looking to adopt?
Is this damage just aesthetic, or do I need to send the speaker back to KEF for repairs?
Sad indeed! I'm looking forward to lacquer devastation in my future... I would recommend soaking up the effects and waiting a couple of years before fixing.
Chances are you would have to pay for an entire opposed driver pair, and I expect toddlers can repeat an experiment...
I just looks cosmetic and obviously you're not hearing anything wrong or you wouldn't ask.
My license plate frame used to say, "No wife, No Kids, No Pets, No Problems". I got a lot of laughs!
After that your cried yourself to sleep at home. :D
Just accept that HiFi needs to be put away until the offspring has grown a certain amount..
An alternative is an "all included" insurance which covers such things. They exist. At a price.
I personally doubt that at such a woofer which isn't crossed high it would make really audible difference but only measurements in the end will show, if you have measurement mic and a PC you could do some nearfield measurements of both the damaged and non damaged drivers and compare them.
I've seen much worse. It will be OK but if you care about replacing them make sure you don't wait too long because the parts inventory doesn't stick around forever these days. Buy new stuff and then put it on the top shelf set away for a rainy day when you want to put in the new ones. Frequency sweep the speakers as they sit now and check for resonances or buzzes in the woofer.
All go and no show. Don't worry that kid will give you many more challenges, just an early test of your fortitude. Mine is 27 and still there are issues. Bet they sound fine.
The only way to know is to listen to them. What are you hearing when playing something familiar, any suspicious noises. Probable not.
