DirtyBumOak510
- Joined
- Nov 21, 2020
- Messages
- 16
- Likes
- 7
What DAC's (under $700) have enough voltage to act as a pre-amp for a power amplifier? Volume control is likely a must unless I add one separately.
I'm posting this in the newbie forum because I'm a newbie and there are parts of this question that I don't understand - otherwise, I'd just go and look them up. Is it just as simple as matching the input sensitivity of an amplifier to the "maximum output" of a DAC? Where and how does impedance factor in? What part of the spec sheets for DACs or Amplifiers should I be looking at? For example, Schiit Bifrost says "Maximum Output: 2.0V RMS single-ended and 4.0V RMS balanced",
For clarification, I'm talking about a DAC that could power a powered amplifier meant for a speaker, not headphones. I'm looking to bypass the pre-amp and go direct from DAC to Amplifier.
Background: I'm starting a system from scratch. It is based on speakers which I recently purchased, Philharmonic BMRs. They were way out of my league/budget but I ended up getting them for a price I couldn't pass up. Ideally, I'd like to have a proper system in place. Ideally, I don't want to throw money at components that I'm going to upgrade later, I'd rather just get it over with now. That said ... I'm on a pretty tight budget. One way of buying some time, and dealing with a pre-amp later, is to buy a good DAC, and a good amplifier, and to bypass the pre-amp purchase for the time being. This would involve having a DAC that puts out enough voltage to feed the amplifier. The amplifiers I have been looking at are typically NC252MP, NC502MP, Hypex500, or Purifi based amplifiers from VTV, Nord, March, Etc. The problem I've encountered is that if I get a March Purifi amp, or a Buckeye NC502, or a Nord Hypex500, then I need a pre-amp ... and pre-amps aren't cheap. The cheapest one I've seen that seems to be well regarded (subjectively if not objectively according to the #s) is the Freya+ from Schiit. That's $900+tax/shipping. That quickly puts using a 252, 502 or purifi amplifier into the multi thousand dollar realm. Nord has an Integrated amplifier Purifi, or integrated amplifier Hypex500 but its $1800. BUT! If I could buy a good DAC (one that I wouldn't need to replace later) that could power the amplifier, that could give me a year (only listening to digital) to save up for a pre-amp and phono pre-amp.
The DAC's I'd been researching are the Topping choices, specifically the D50s because it says it can act as a pre-amp for power amplifiers, and it has a couple of things on my need list (Optical IN specifically, and volume control). In order to be a DAC+Amp system, the DAC would need a volume control, which the D50s does. Some of the other offerings from Topping seem to fit the bill as well. The others I'd looked at were the RME ADI-2 FS (above budget), and Khadas Tone Board (March Dac1, Nord Easy Stream) - but these typically don't have volume control. I suppose volume control could be bypassed with a Schiit SYS for only $50 which wouldn't be too big of a hit.
The reason I'm on a quest for the right components is because I don't like re-selling "band-aid" equipment (at a loss), or hodge podging an OK setup. I'd rather buy a few of the right components and add the others as I can afford them. The Pre-amp and Phono-Preamp will be a major addition, but I could live without them for a while if I had Optical Input and enough voltage with RCA/XLR output to feed a good amplifier. If I can't come up with a solution ... I think I'm just going to have to live with a Stereo Receiver for a year or two while I save up for the right components. This would lead me to the new Outlaw rr2160Mkii, which would have a phono-preamp, enough AB amplification to drive my speakers, pre-outs for subwoofers, a Burr Brown PCM1792a DAC, optical inputs, RCA inputs/outputs out the wazoo, and one remote that rules them all .... it checks all the boxes.... but its not a Schiit Freya+ with a Khadas Tone board DAC, with a nice good budget phono preamp (Schiit Mani?) driving Stereo Purifi Amplifiers ...
So ... uhhhhh.... What DAC can power a Purifi stereo amp? (" Input Sensitivity: 8ohm 2.52Vrms 10.24dBu")
