DAC recommendations
SiR
Hi,
being a new Marantz owner ( PM 8006 ) like to know anyone using / used PM8006, to give your suggestion / recommendation based on your experience with it, about the DAC that gives Transparent / Neutral sound at the budget of around $700 ?
As of now using WiiM PRO as a Streamer cum DAC, Speaker PSB Alpha T20
TIA
JSmith
Algol Perseus
The amp output only has a SINAD of circa 69dB... so you will be limited by that anyway.
JSmith
S
SiR
JSmith
Being a Newbie, what is that " The amp output only has a SINAD of circa 69dB " mean ?
If its ok with you @JSmith to give a brief of it to get an understanding
TIA
JSmith
Algol Perseus
TIA
Certainly (brief)... SINAD (signal-to-noise and distortion) is basically the reciprocal on THD+N (total harmonic distortion + noise, assuming over the same bandwidth). It's easier as it's a positive whole number. If you look at what I posted you can see the THD+N figure for 5W output and here testing is done at 5W (many other specs at 1W).
0.1% THD+N is +60dB SINAD
0.01% THD+N is +80dB SINAD
The measurements I posted are not as thorough as done here, but is giving us a general indication as to noise and distortion. So what I was saying is if you have a DAC that is 120dB SINAD... you are limited by the SINAD (noise and distortion) of the amplifier itself.
I'm not saying that will be an audible issue... but I'm not saying it may not be either, depending on many factors.
What DAC are you using now and what is wrong with it?
JSmith
Reactions: SiR
VintageFlanker
Paris
Well... not quite. Audio Poland's instrumentation is known to have some pretty high noise floor that totally mess THD+N figures. It is useful tho, to observe clipping behaviour and power.
Anything that fits your budget. Any good enough DAC from 80 to 700$ will have transparent sound. You would have to make your choice based on design, features, connectivity and so on.
S
SiR
Thanks a lot for your swift response @Smith
" So what I was saying is if you have a DAC that is 120dB SINAD... you are limited by the SINAD (noise and distortion) of the amplifier itself. "
Can I understand that the limitation of the amplifier with its SINAD may not help the benefit of DAC's 120db SINAD ?
"What DAC are you using now and what is wrong with it? "
As of now using WiiM PRO's DAC
MaxwellsEq
TIA
The difference between the quietest sounds you can hear and the loudest sounds the amplifier can make is the signal to noise ratio. SINAD covers this and includes the distortion (errors caused by the electronics). CD and 16 bit DACs have at least 96dB (decibels). This (because dB is a logarithmic scale), means that any DAC has hundreds of times less distortion and noise than your amplifier.
So your amplifier will mask any differences between DACs. 69dB is not terrible, but it could be better.
Reactions: SiR
S
SiR
Welcome your response @VintageFlanker
As U could understand now, why I brought the topic of LPS usage in a thread in WiiM forum, to see any betterment in the Wiim's performance, as the DAC in it is used
JSmith
Algol Perseus
@VintageFlanker measured this and posted the results here;
Yeah that's why I added the caveat "The measurements I posted are not as thorough as done here", meaning take with a grain of salt. ;)
JSmith
S
SiR
@Smith @VintageFlanker
I went through it as soon he posted it and after reading his review I was satisfied that I got a decent Streamer, thank HIM for the review
Since its digital transport is excellent, now I wanted to use a good DAC and hence came here
JSmith
Algol Perseus
You may like this, recently tested and only $200;
Otherwise, have a look through the Review Index;
JSmith
voodooless
Netherlands
Please don't waste any money on that. The measurements show that it basically scores only a hair worse than the DAC datasheet on distortion and that the noise is already pretty good. You probably could have bought an external DAC for the same amount of money, and actually gotten an objective sound improvement. If you could actually hear that though, is a totally different story.
Mac Arthur
I would add a bit on the budget and go for the RME ADI2 DAC FS.
Tested by "the boss" here. I owe one and it's amazing and with a lot of additional features.
voodooless
Netherlands
The only really useful feature I see in this context is Loudness, but only if you use the volume control of the DAC. The WiiM already has quite a bit of EQ possibilities, much more than the RME.
To be honest, the best money spent is probably on a measurement microphone so you can correct your in-room response via the WiiM. It will give you an actual, substantial sound quality upgrade.
VintageFlanker
Paris
Or just sell your WiiM Pro and get a WiiM Pro Plus instead...
You just buy peace of mind and won't have to worry anymore.
drewdawg999
Suburban Los Angeles
If you're willing to splurge a bit then the SMSL D400 Pro looks nice in silver. You're paying for a nice and shiny chassis, MQA and flagship AKM chips. Could get equivalent performance much cheaper but it just wouldn't look as nice. I prefer not to pay for MQA so I have a D-6, DO100 and Sanskrit 10th mkII. All transparent to my ears, which are satisfied by 90dB SINAD, far surpassed by all 3. The D-6 edges it out for me due to DSD performance.
Reactions: SiR
