I am looking for a reliable DAC to use with 2 (maybe 3 sources). My sources are a media streamer/player, a Marantz Pearl CD player and maybe also a FiiO M6 portable media player. The idea is to connect the devices via USB, CoAx and BT respectively. My amplifier (Yamaha S2000) has both RCA and XLR inputs although I have never used the later.
My first thought was to get the Topping D50s as it is available locally and is affordable. Then I figured since I keep my audio components for a fairly long time (10 years+) why not stretch and consider the SMSL SU-9, SonCoz SGD1, Gustard X16, or Topping D70BT all of which I would have to import. Apos Audio does not carry SonCoz but has the SMSL for $440, Topping for $470 and the Gustard for $500. There is another site called Audiophonics that sells the SMSL for €430, SonCoz for €500, Topping for €550 but they do not have the X16 in stock (they have the A18 for €560).
A friend of mine tells me that these "Chi-Fi" DACs (his terminology, not mine) are not reliable and that I should consider Denafrips Ares II or RME ADI-2 DAC. He has a Matrix Audio Element.
Please advise.
1. Are Topping, SMSL, Gustard and SonCoz reliable? or should I ignore them and get the Ares II or RME?
2. Is there a huge difference between the D50s and the D70BT, SU9, X16, SGD1 etc?
3. Between the SU9, D70BT, SGD1 and X16 which one would be preferred?
Thanks.
Please advise.
Thanks.
