I posted this in the roon forum but so far no response..
Im currently experimenting with Convolution filters for my Headphones. I Downloaded the 44.1khz and 48khz files from Github, added them to Roon and it works just fine. but I was wondering what the “taps” exactly mean, what are 20k taps exactly doing ? and how is a convolution filter different from a 10 band parametric EQ?
I noticed the Convolution Filters make everything more quite and I need a bit more volume. is it ok to disable volume levelling when using them instead of parametric EQ?
is it better to use the P-EQ for DSD output since I don’t have the matching 384khz files for the C-Filter?
I played around a bit and this is what my signal path looks like in my living room.
my other setup is able to do native DSD512.
Headphones are the meze liric and I downloaded the auto EQ wav files from oratory1990.
