I now have a pair of dynaudio emit m10, should have been the latest version but isn't do to an error on the website
Some review meassure a very low sensitivity of 82.3dB (averaged 300Hz-3kHz on Listening Window, 2.83V/1m)
Despite that im using a 2x20 watt in 8 ohm and 2x30 watt in 4 ohm nad all in one unit and it's actually ok, but it's not clean when playing loud do to being class d,low wattage and mainly made for use with a tv so not a ton of power (on paper) but it can play loud.
I have a Fosi Audio BT20A im thinking of upgrading to something better but still around 100 euros, my amp is 2 years old and i think there has been made some newer models that sound better,has the same or more power for 100 europs (i have 24 volt 10a power supply in case i need more power for a new ultra compact amp).
What can be recommended ?
Not shure many amps has 2 x 100 watt in 8 ohm but in 4 ohm it should not be impossible
I would like double the power no less, if not, it should be the best sounding 100 euro amp, if it has no more than 2x20 and 2x30 watt in 8/6 ohm,
