Choosing between budget amps for DCA Aeon RT
Firefly00
New Zealand
Hi! Fairly new to hifi, building a first real setup (ditching the iPad + Grado SR80 combo). The setup I’m looking at is a budget amp + Aeon RT.
amp options that are available where I live (NZ):
Topping L30
Fiio K5 pro
Ifi Zen DAC
Schiit Magni 3+
Schiit Magni Heresy
Are any of these options actively a bad choice, or am I just massively overthinking it?
cheers!
Well, what will be your new source? The ifi Zen DAC appears to be a combo unit. What's your budget? Maybe the Topping EX5 which sells for $350 US might be $495 NZ? See here. I can't connect to amazon New Zealand. But, I'll bet it's available there too.
I’m taking the approach that I should get a good pair of headphones, and then an amp capable of driving them. Was just going to use a lightning > 3.5mm adapter out of my iPad, but if there’s a good combo option I wouldn’t pass it up. Budget is around 250 usd
thank you for the help!
The Schiit Modi3+ and Magni Heresy stack is good value. I've been using it to drive my Aeon RT before getting the RME ADI-2 DAC and there is no difference in sound quality on my listening levels (not very loud).
You might want to consider the IEMagni as well since afaik that model has DC protection which is a nice feature to have.
I found the iFi Zen DAC to lack flexibility as there was audible noise with high sensitivity headphones.
