"Cheap ass" cables and build quality. Good or Bad.
Nobody want to pay much for something like that; that's why. If it's that lousy, then it had better be cheap.
Unless, of course, it were art*.
______________
* Note my cunning use of the subjunctive. :)
I sold tons and tons of gear and near everything came with those thin cheap RCA cables with chrome plating and thin copper cores. These are the same cables in use decades later and found in junk drawers/boxes after decades and still in use. What gives?
They were Japanese. Even their 'free' cables in the box were better than stuff you can buy these days.
I've got hundreds of them too, and they are as good as the day they were made.
These have been hanging over my bench for about 30+ years and get used perhaps thousands of times for testing. Came with the early 1990s DSP processors.
Never had corrosion like that. Then again shopping for "pretty" cables like those isn't something I've done either.
Whether intentional or not. They were exposed to something very corrosive. You're going to find that something caused the corrosion to happen.
For all I know the way the armor was added, the glues used, what it was made out of, what it was washed in after assembly, and the box it was kept in.
Like I said I've seen some weird shit happen with wire, and terminal ends whether male or female. The use of the WRONG solder mainly acid core vs
resin core will do exactly what you see over a period of time
or use acid as wash/pre-treatment before soldering the assembly.
I've seen people who are assembling machines and there are a few different types of solder used. I've seen them mix up the solder and grow
barnacles as a results. Solder up a HP plumbing joint and then grab the wrong spool of solder and solder in a sensor. I've seen that quite a few times.
The bad part is it's usually UNDER some shrink tubing in a 2" thick analog loom with 200 wires in the loom.
Digital machines certainly have their advantages, BUT at one end or where sensors are required, those wires are analog plugging into a junction box/cann bus
node for digital wiring and a voltage + & - wire.
BTW I'm NOT saying you did it, I'm saying someone else did. I'm a retired mechanic, and all I ever did was fix someone else's mistakes. I did get pretty pissed
when they would take a hammer to something and cost 10K when they just needed to turn something in the opposite direction.
Regards
Cheap cables often fail from poor soldering, weak shielding, and bad connectors. Skip the $2 no-names mid-tier brands last longer without snake oil pricing.
