- Joined
- Dec 12, 2019
- Messages
- 15,965
- Likes
- 36,083
heh-heh-hehAre we still discussing cables here?![]()
he said "Easy access from the back side"
heh-heh... heh-heh-heh.
But I think many people here are going overboard in this backlash, and trying to justify the lowest possible price.
Why stress about lowest possible cost?
Be thankful. Without that weather and the bravery of the Scots you guys would probably speak Italian todayWe are not renowned for high humidity here in good old NW England.
Wow those are some old SS, but they had all kinds of power and VERY very built. I had a buddy that used them to drive Infinity QL2s. He was using a C20 for theC-28 and an MC-2100
I can assure you they weren't. December 2022 I rearranged my study into a media/cinema room, and they were disconnected. Since then, they have been in a box on a shelf in that room - along with some other electrical stuff and old camera lenses. None of which have suffered any ill effects.Whatever happened to those cables was added
whether intentional or not. They were exposed to something very corrosive
But look at the alloy body shells - identical material with identical anodising on them, and the plastic strain relief to the wire is identical. They are even exactly the same diameter. Pretty clear to me they were made in the same factory - using the same materials on the contacts. Probably also assembled into a cable there.My reasoning is simple, WHY Both terminal ends, I know they weren't made the same way. They are different terminal ends,
A faulty connection does affect SQ. I've had a number of audio cables go bad and it really affected SQ. A common failure mode is intermittently getting only half as much sound. The stereo effect was pretty bad. Put a better cable in and it sounds much better.Good and Bad examples welcome. Anyone trying to divert the discussion even tangentially towards sound quality...
Perhaps it was the properties of the box. Have you tested the possibility that time moves faster within the box? Can Amir's AP test for compliance within Relativity? Perhaps it has potential in the marketplace to ripen tomatoes and avocados to perfection in no time. I'm just trying to turn lemons into lemonade here... while not breaking the laws of physics... ?I'm assuming it is some form of galvanic corrosion, possibly initiated while they were in use. But I don't really know. I just took them out of the box and there it was.
Looks like having had too much load of 'Blue'tooth or 'Blue'ray ... what did the manual say about that... ?I couldn't find a better thread - so this one is specifically for discussion of build/manufacturing quality of cables at the "sensible" end of the price spectrum.
Good and Bad examples welcome. Anyone trying to divert the discussion even tangentially towards sound quality will be black holed into the time vortex. Similarly "snake oil" cable discussion should be taken to the already appropriate threads. The aim is to guide people towards cables which are good - and those that should be avoided.
For my immediate example. Here is me trying to cheap out by buying one of those "brands" on amazon, that you've never heard of, and often can't even pronounce. What can go wrong with a cable? I thought. Well clearly the manufacturer had no idea what materials to use, despite the claim "gold coated for corrosion resistance", or something like that. These have been used for about 18months, and have then sat on a shelf in my (dry, heated) media room for about 2 years. Imagine this going on inside your expensive audio gear. Amazon review has been left.
Do you think... perhaps... there was a cat in the box? And, just possibly, a radioactive source capable of random but (EDIT: ultimately, via an intermediate poison) lethal decay?Perhaps it was the properties of the box. Have you tested the possibility that time moves faster within the box? Can Amir's AP test for compliance within Relativity? Perhaps it has potential in the marketplace to ripen tomatoes and avocados to perfection in no time. I'm just trying to turn lemons into lemonade here... while not breaking the laws of physics... ?
Nobody want to pay much for something like that; that's why. If it's that lousy, then it had better be cheap.Do you think... perhaps... there was a cat in the box? And, just possibly, a radioactive source capable of random but lethal decay?
PS Isn't it funny (from the perspective of symmetry) that one so rarely hears about any expensive-ass products?
... perhaps... or perhaps it's just a Schrödinger's Cable... famous for it's simultaneous live and dead sound... until the box is opened.Do you think... perhaps... there was a cat in the box? And, just possibly, a radioactive source capable of random but lethal decay?
