You are selling a "reclocker"
- that assumes there is something wrong with clocks, something that may have been true in the past but is not obvious today. Do you have evidence that there is a problem with the clocks of current well designed devices?
quote
"What you consider super-expensive and what I do may be worlds-apart I'm afraid. Most of my customers have systems starting at about $30KUSD. Most have speakers alone that cost that."
- that sounds a bit arrogant, I can assure you that some people who have $30K speakers and $50K systems can't hear differences between functional cables in a blind test. Anyway, that is "convenient escape door 1" for you. If the customer doesn't get the benefit of your device he has a poor system/poor ears/poor training.
And then this
"This proves that the molecular structure of the conductors is important, almost as important as the R, L and C."
That's an incorrect use of the term "molecular", metallic bonding would be more appropriate and is fundamentally different. It is always a bit amusing to hear designers talking about the molecular properties of their wires when they (alloys or else) are not molecular in nature... I mean, you could expect people making ground and sound breaking discoveries in cables, not to use vague, inaccurate terms.
To the questions
1. The measurements show no effect at all
2. Your device degrades the measurements.
3. Your device improves the measurements.
you have your escape door 2 - namely, measurements would be poorly done and escape door 3, measurements equipment would be inadequate. That's a bit easy, isn't it?
"I can easily hear the difference between ALAC, FLAC, .wav, AIFF and other formats playing the same track"
Here, you seem to claim to be able to easily hear differences between lossless formats. That's an amazing claim with profound implications in both information theory and physics. As such, it would have to be tested with a five-sigma level of confidence as opposed to the two-sigma level often used in social sciences. How has the test been conducted and at which level of confidence? Is the data public? Now, I understand that to reach that five-sigma level of confidence, you may have collected terabytes of data. How much storage do we need to send you so we can have a look at that data?
"Transient capability of the digital part of the DAC has nothing to do with this. The power delivery must support di/dt in the 1amp/usec range in order to not result in distortion in the analog output."
That statement seems to have been a bit hard to parse. Could you please clarify it? If what you are trying to say that a good amplification chain is required behind the DAC, no one will dispute that, just as no one will dispute that good speakers (whatever that is) are required after the analog amplification stage. But how is that relevant to a reclocker? Here, I can kind of guess what you are trying to say, but other members have asked specific clarifications and I haven't seen an answer.
Now, now let's go back to the basic claim that your reclocker improves something (still not quite clear in my mind) 10 or even 100 times... Even with the vagueness in the size of the improvement, that is a testable claim. Great.
Outcome A: Let's assume that you are a great designer, a bit like Rob Watts for example, and that a real improvement in measurements does indeed occur... The obvious question is then is it audible? For some reason, even though I own a couple of what you arbitrarily describe as high-end systems and speakers on the base of price, I have a very hard time noticing differences between fairly well behaved and similar devices that measured 95dB, 105dB and 110dB in some metric. I am sure I would not be able to notice anything if one arbitrary metric goes from 110dB to 120dB. And, if by some miracle I was, I would turn myself into the nearest research center to be studied. But yeah, in that outcome, you'd have deserved the right to call yourself a great designer, even if your goal is a bit pointless in practical terms.
Outcome B: no measurable gain or even a loss. In that case, just typical snake oil audio stuff. But no worries, you have escape doors 1/2/3
Sigh...
