azaudiogeek
- Joined
- Jul 18, 2022
- Messages
- 2
- Likes
- 0
Thanks Sir for the inputs. I have had 5308ci from 2007 that works rock solid to-date. Upgraded system with x6200W from my dad's house as he was downsizing his posessions. I followed your advice above and integrated such that the current 7.1 channels are driven by 5308ci - remains unchanged. Remaining 4 front and rear heights are driven by x6200W internal amps.To answer your question, you can totally do what you want to do. Until last week, I was running my X6700H in “mix” mode. Meaning I was using external amps to drive my LCR, surround and rear surrounds while driving my 4 x Revel M55XCs ATMOS speakers with the X6700H internal amps with ZERO issues. Last week got an Emotiva BasX A4 to drive the ATMOS speakers and now I have switched the X6700H to pre amp mode. Results are very similar other than the X6700H runs just a bit cooler. Before the X6700H I was doing the same with a X6500H which is now in my bedroom also driving a few speakers with internal amps and some with external amps. Next week I’ll be running the X6500H also with all speakers driven by external amps, though.
5308ci's maximum volume is +18db, kept it at +10db in EXT.iN Direct mode and all 7 channels are driven without issues. My fronts are Definitive ST Tower (350w) while Center, Surrounds and Surround Backs are all Def Mythos 10 (300w). Have dual SB-4000 driven directly by x6200W's sub1 and sub2 outputs. Actually I spliced Sub1 output to feed powered FL and Sub2 output to feed powered FR. Ran Audyssey and its just rocking!
I have few questions though -
There is a provision in 5308ci to adjust Analog input volume by +12db for all Pre-Inputs. Currently I set it at 0db. Do you think I need to give maximum flexibility to x6200w by putting +12db?
Maximum volume on 5308ci as mentioned above is set at +10db that is 90% or max volume limit of +18db. You think I should keep in EXT.iN mode 100% or reduce it to 80% to 0db?
Thanks
