Galliardist
With the pulling rank line I used, I'm referring to the line where you told us that "good setup is important" for vinyl. It's used as a putdown in these parts. Nothing more. I don't want to cut you out of the conversation, that's why I replied to you, because you were being missed.Discussions that don't have more than one side aren't discussions. Is it "pulling rank" to disagree with you, or are you pulling rank to try to shut me down?
My goal is to get digital to sound as good a vinyl, because I listen more to digital sources. Now granted, part of the reason vinyl often sounds better in my house may be because the newer vinyl here is all audiophile pressings, where there's simply more care in their production than in average digital output. Part of it may be that the vinyl equipment has had longer to evolve than digital. All reproduction introduces "color." Those designing phono stuff have a longer legacy of wisdom in tuning that color so as to contribute well to a range of musics. Perhaps you like some of the digital colorations better. Nothing wrong with that, either way.
The ES9038Q2M-based Emotiva DAC I put digital signals through has 7 different filter settings, only 3 of which sound decent to me, and I end up switching between those to get the best result for particular recordings. Perhaps there's some other DAC that would sound better (to me) than vinyl. This one's as close as I've gotten so far, better than the ES9016S DAC in my Yamaha pre-pro, and the AD1955 in the Emotiva CD player. I'll be more than happy if I can get digital to sound better than vinyl here. But it doesn't, yet. I'm not the only person with this experience. And it's not that digital doesn't sound very good indeed. It's just not quite up to the best vinyl yet. I hope in the future, with more system upgrades, it becomes so.
I see the problem you have, but not the cause, and therefore not the solution. My first point would be to (temporarily at least) remove the Emotiva, and listen directly from the Wiim Pro DAC. Cut out listening to the filters and get the "purest" digital into your setup. (I'm assuming that you have equipment that allows that). That gets you "as good as it gets" accuracy at your source. We know that in most cases, people in controlled testing prefer the more "accurate" source by conventional measurement, and if something isn't right with the Emotiva, we have good measurements for the WIim. I hope that makes sense.
We don't appear to have great evidence for digital vs vinyl in blind or controlled testing. That's because it is difficult to test without things like noise and distortion giving away which is vinyl for the most part.
If I were you, I would listen to just one source for a couple of weeks, and then just the other for a couple of weeks. See if you listen in different ways to the two formats, see if you can start listening to digital without that "vinyl is better" thing going on for a while. I don't know that you can reverse a decision in a situation like this, but it would be great to shift from thinking of this as a "quality" thing to a "preference" thing. Both are perfectly adequate for listening to music on. There's no need to worry about what is what, unless it changes the way you listen.
You mentioned a pre-pro. Are you listening on a multichannel system? If so, are you using 2.0, 2.x or some other method to listen to stereo? How do you feel about stereo vs more channels? Could you detail the rest of your system?
