MatrixS2000
- Joined
- Aug 22, 2023
- Messages
- 798
- Likes
- 1,743
NO!!! Definitely not saying you are doing anything nefarious.What do you mean when you say I'm spoofing the DR numbers? I hope you are not suggesting that I fiddle with the numbers.
What I mean by that is that you are simply looking at DR numbers. That is all. What I am showing you is that is not enough. The waveforms and the dynamic traces you created do not match the waveform or the dynamics coming off the vinyl rip. That is why I showed you the comparison of the vinyl rip dynamics to the dynamics of the modified CD back to original CD waveform. They are not similar so all that happened here is you landed on the same DR number but with a different waveform. You spoofed a DR number - you did not recreate the vinyl waveform that produced the higher DR number.
Just because it is common does not mean it is the best or even the preferred. It is also has not been developed for years so is outdated and uses a less accurate algorithm (PLR based) algorithm. PLR is Peak to Loudness measurement. Peak measurements are not as accurate as the tool I used. The loudness database tells you this:I use one of the most commonly used DR Metering tools, which is recommended by the DR Loudness-War webpage and available in Foobar2000, which is also widely used. As that one is probably one of the most commonly used DR Meters, the result will also be highly representative of many of the measurements posted on that popular webpage.
MAAT DROoffline uses PSR. Any tool that uses PSR (peak to short term) as the measuring algorithm can be used. Tools utilizing this algorithm are much more accurate and can detect things such as squashed DR due to loudness maxmimation. I use Adaptr Audio AB Metric as it gives me a trace but there are also other tool such as Ian Sheppard’s Dynameter that can do the same but won’t give you the handy history graph that AB Metric does.
The last line on any album that is measured on the loudness database describes which algorithm was used. I tend to ignore the ones measure with PLR because it is not accurate but that also does not mean that that piece of music is the same as the CD version of a song with monoing of the bass, HPF and de-essing applied to it.If the tool you use, for any reason, is not showing the same result as the most common tool used on the DR Loudness-War, it’s simply not representative for all the results posted on that website (which is by far the most popular website for these type of comparisons).
I don’t doubt these numbers, I doubt your conclusion because as I showed, the dynamics of the CD with restored bass or without do not match the vinyl dynamics. You simply created a 3rd and 4th version of the song that happened to have the same DR numbers. The PSR graphs clearly show this.This is the dynamic range of the digital/CD release and the original master file:
And this is the dynamic range of the vinyl rip, which was made from an original master file with only DR8:
And here is the dynamic range of the digital/CD release after applying the usual things done in the preparation of a vinyl record, as a high-pass filter, mono bass, and a De-esser. The result ends up with the same DR as the vinyl rip:
Again, mastering engineers are literally telling you that vinyl master have no loudness maximization process applied and that they are more dynamic.If anything is spoofing the DR numbers, it's the commonly used tools used when preparing the audio file to avoid technical limitations of the vinyl format, which then show up in the reading of the dynamic range.
Use better tools and you can trust them.And I'm not saying there are no vinyl releases out there that aren't more dynamic than their digital/CD counterpart. I'm just saying that the DR readings on their own can never be trusted, and even if the numbers look better, it's still possible that the vinyl was made from the same dynamically limited master as the digital/CD release.
The example song you used did not have much limiting. If you followed the same as the Ian Sheppard video where the digital “master” was brickwalled, you would find that when you add back the bass, the DR drops again because you cannot get rid of what the limiter/compressor did to the file.
