D
Deleted member 58865
Guest
Is there any? I just want volume control for RCA cables without channel imbalance.
www.audiosciencereview.com
Not perfect... but very cheap;I just want volume control for RCA cables without channel imbalance.
I don't know how expensive it would be. Topping D10s has 112dB of dynamic range. So, with the DAC volume currently at -16dB, I get 96dB of dynamic range.a high dynamic range DAC with digital volume control
However, reducing DAC volume still reduces DAC's dynamic range.
Why?Selecting a lower resistance is always the best. (10k or lower)
You mean reducing DAC volume is just as good as setting it at 0dB and reducing the volume on stepped attenuator?The dynamic range of your hearing is about 70dB at any 'average' level so music at 120dB level means you won't be hearing any sounds at 50dB SPL at that moment (you can later on when the music is silent).
It lowers output impedance which lessens the effects of the cable on frequency response. It also lowers thermal noise which might be amplified further down the signal path. Lower resistance has less thermal noise than higher resistance.Why?
With the DAC volume at -16dB, application volume at 100% is loud enough to disturb me and people around me. I keep application volume at 25~70%.
It seems 121dB is the best dynamic range you can get from DAC.
My AIYIMA A07 amplifier doesn't have 96dB of dynamic range because the AC/DC power adapter is not clean enough. If I buy a better power supply, I may get more dynamic range from the amp.
Really, AIYIMA should step up its game and put stepped attenuators in their amplifiers. I would buy AIYIMA A07 with a stepped attenuator instead of potentiometer as long as the gain structure of the stepped attenuator is correct.
