Brutefir for Volumio now supports REW EQ filters
Krunok
Zg, Cro
If you prefer to use REW not only as a measurement tool but also as a tool for automatic/manual creation of EQ filters here is what you should do to use those filters with BruteFIR convolution engine for Volumio:
1. Create your filter in REW
2. Export the filter you created using "Export filters impulse response as WAV"
3. Use REWs default settings for export
4. Copy filters to BruteFIR filter directory
5. Use the following settings in BruteFIR to activate your filters (set input attenuation according to the max gain of your filters):
7. Measure results with REW and, if necessary, correct your filters.
8. Enjoy your music!
My plelasure guys. :)
Let me just add that input attenuation in BruteFIR settings must correlate to max boost of the individual filter in REW. I advise you to look at the boost of each filter in both channel to determine max boost as it may be that actual max boost never reached "Individual Max Boost" setting in REW. If actual max boost is lower than that setting than set input attenuation accordingly.
Hello, if at the REW export settings "normalise samples to peak value" is checked, is another attenuation in Volumio necessary? As far as I understand the REW manual this reduces the filter gains so the peak value is 0 dBFS anyway.
Best regards, jan
Gentlemen
Im already using exported filters in text format from REW in equaliser APO.
Is there any benefit of using exported filters from REW in wav format into convolution in equaliser APO instead.
Gentlemen
Only that its quicker and easier to import filters which are different for L+R, disadvantage is you need different wavs for different sample rates.
I tried using filters separately for left and right channel. But never worked out well. When i applied the filters this way and measured with umik-1 with filters in place the output was all over the place.
Then i made filters for both channels together and the result was very good after a few adjustments.
Anyways when you say "different wavs for different sample rates" does it mean if im playing 41khz, 44.1khz, 96khz, 192khz files they all will need different wavs to be uploaded into equaliser APO..?
For my room separate L&R room correction below 200 Hz sounds better even if the sum doesn't look as nice, each must find what sounds better for him not what looks better from measurement point of view as our perception is different than a mic.
Rather depending on the output sampling rate you have chosen for your sound output device, but don't worry, EQ Apo warns you in that case of wrong sampling rate.
rather depending on the output sampling rate you have chosen for your sound output device, but don't worry, EQ Apo warns you in that case of wrong sampling rate.
Thank you so much for your valuable feedback. Its clear now.
Have a great day
