daniboun
Thanks that was a question ))
Yeah those ribbon connector receptacles suck. I have mine so the input stays put on the shelf, but it will probably get the intermittent fault back the instant I move it from its current location. I am thinking about soldering the wires right to the pins like I did when I installed the digital output mod on @BDWoody 's 'Wandering Puffin.' It would be a bit less modular, but it sure would stay connected. The Boxem board seems like a smart and sensible solution.One other good reason to use a PCB to bridge from the ribbon cable is strain relief. Despite improvements when using the Ghent connector, twisted-pair (tp) cables (like Mogami wire) place more force on the ribbon cable connector. This is why you see some implementations taping the connector in place. I suspect a volume producer would hot glue or use something to retain the connector.
Despite the apparent robustness of tp wiring, my experience after building several Hypex amps is that the heavier wire can pull the connector away from the header. Without strain relief, the result is marginal connection that can reduce output and/or introduce hum.
For my next builds, I plan to use the eval board as it adapts the ribbon cable connections to input connectors with locking retention. So, even without needing to repurpose a one case for different size modules, Boxem‘s PCB provides a better system solution in my experience.
Without the black fluffy thingie (TM) idiots like myself tend to be electrocuted when they do not pay attention to where they put their fingers.
Prepare to be disappointed, I am French
I know... But since I am an half full glass guy, I have always in mind that I could be Italian.Nobody's perfect.
Looks like some (a lot?) people are confused by what the black fluffy thingie (TM) around the IEC socket. Is it hiding something like a filter or a secret module? If there is nothing to hide, why is it there?
The answer is that the IEC socket looks like this without the black fluffy thingie (TM):
As can be seen, there are metal parts. And these metal parts can be live pending connection to mains and rocker switch position. Without the black fluffy thingie (TM) idiots like myself tend to be electrocuted when they do not pay attention to where they put their fingers.
The fuse is not user replaceable. This fuse is installed as a last barrier in the case when the SMPS safety mechanisms would not operate. Said differently, if the fuse is open, that means that the SMPS went bersek and is destroyed. So it is not only the fuse that would need replacement but the entire board.Is there a user replaceable fuse on the amplifier board? I've seen these IEC sockets with fuses but it doesn't look like this one has a fuse? Not meaning to be critical, just curious - this is a very clean build.
Then if it is kept hot (as my mother keeps our home at 26 degrees or higher) then there is little leeway for for heat dissipation.Very nice. Theoretically it could be half the size.
Nope. Out of curiosity, why would you want to disable it?I've looked in the review thread and here, but didn't see any indication: Can the auto on/off be deactivated? Maybe using an internal jumper?
As far as I understand, it takes a second or two for the amp to switch on from standby/auto off, right? In any case, it's not instantaneous. I'm thinking that this could potentially be annoying in some scenarios where I occasionally have some audio on and longer pauses in-between: e.g. reading something, then switching back to music or a youtube video. In that case, the first seconds of the audio would always be cut off and I would have to restart it. In this scenario, which is pretty common for my usage, I might prefer to deactivate the auto on/off and just live with the higher idle power draw. For the NCore modules, that is pretty low already.Nope. Out of curiosity, why would you want to disable it?
Understood. Thanks for your feedback!As far as I understand, it takes a second or two for the amp to switch on from standby/auto off, right? In any case, it's not instantaneous. I'm thinking that this could potentially be annoying in some scenarios where I occasionally have some audio on and longer pauses in-between: e.g. reading something, then switching back to music or a youtube video. In that case, the first seconds of the audio would always be cut off and I would have to restart it. In this scenario, which is pretty common for my usage, I might prefer to deactivate the auto on/off and just live with the higher idle power draw. For the NCore modules, that is pretty low already.
I think the auto on/off is pretty cool and certainly unique amongst NCore implementations. Nonetheless, making it configurable would be a plus for me
For me, the fact that it has auto on/off (as well as a form factor that is not insanely tight) are reasons that I am considering this amp over almost all others. Unfortunately, renovating a house that my wife & I just bought to a livable standard (as well as moving from the Island of Guam to an Island off of Charleston, South Carolina (USA) (where I grew up) and all that entails, has prevented me from already having 1 of these.Understood. Thanks for your feedback!
