There is no way that speaker is adequate to use as a center channel...I seriously doubt it's even equal to the speakers in any decent TV. Cambridge doesn't provide any actual specs but it appears to be a 2-way speaker, so no it will not perform well laid on its side.
The in ceiling minx seem like they’d be decent atmos speakers if they are crossed over appropriately.It’s actually far better than speakers I’ve heard in any modern tvs. Minx 22 is a 1.5 way design with the lower unit being a custom bmr woofer to reinforce the low mids/high bass. Not two of the same driver put In parallel, they work really well in my set up for a surround system where my other options would be a sound bar only due to space.
Anyway with that aside my question still stands on wether dispersion characteristics are determined by the orientation of a speaker like a BMR?
A 2-inch driver is not a woofer...just saying.It’s actually far better than speakers I’ve heard in any modern tvs. Minx 22 is a 1.5 way design with the lower unit being a custom bmr woofer to reinforce the low mids/high bass. Not two of the same driver put In parallel, they work really well in my set up for a surround system where my other options would be a sound bar only due to space.
Absolutely and the small minx12 are supposedly excellent for height channels, philharmonic towers use little $20 bmr drivers in their $4000 tower speaker because they perform so well.The in ceiling minx seem like they’d be decent atmos speakers if they are crossed over appropriately.
Wait, you are saying the Minx 22 is better so you already have one? I mean, just play content and move off axis in both orientations. But yes, vertically the radiation is going to be messy and much more limited than horizontally -- just look at any 2-way speaker review here and realize it will be worse as only a 1.5-way. A driver type doesn't magically change physics.
No.Is the dispersion equally vertical and horizontal?
I think the OP means the BMR driver by itself, not the Philharmonic "BMR"s. I almost thought the same thing at first until I saw the other responses and re-read the OP's post.No.
Source:
Measurements for speaker Philharmonic BMR
www.spinorama.org
- Horizontal directivity is (-80.0°, 80.0°) between 1kHz and 10kHz. Angle computed for +/-6dB.
- Vertical directivity is (-20.0°, 20.0°) between 1kHz and 10kHz. Angle computed for +/-6dB.
Horizontal and vertical dispersion are the same for a single BMR driver. No BMR driver has 180 degrees dispersion, but it is very wide.Noob question, bmr is known for its wide 180 degree dispersion but is that only horizontal?
If I were to say use a Cambridge minx 22 on its side for a center channel would it matter?
