Can you write it on a notepad, I don't know how to do it, thank you (For apo equalizer)
[ATTACHE]227485[/ATTACHE]
Ok thxJ'ai joint les filtres d'égalisation que j'utilise. Le résultat est assez proche de l'oratoire.
By me.. its good?
Not entirely certain of your question. Can you expound some please?By me.. its good?
J'ai copié les filtres d'égalisation, j'aimerais avoir votre avis. C'est bon ?Pas tout à fait certain de votre question. Prévoyez-vous en expliquer certains s'il vous plaît ?
Can you equalize this for me please ?(txt file)I've attached the EQ filters I'm using. The result is fairly close to oratory's.
Is this what you’re looking for?Can you equalize this for me please ?(txt file)
Or (the best ?)I will compare the 2Is this what you’re looking for?
AutoEq/results/oratory1990/harman_over-ear_2018/Beyerdynamic DT 900 Pro X at master · jaakkopasanen/AutoEq
Automatic headphone equalization from frequency responses - AutoEq/results/oratory1990/harman_over-ear_2018/Beyerdynamic DT 900 Pro X at master · jaakkopasanen/AutoEqgithub.com
AutoEq/Beyerdynamic DT 900 Pro X ParametricEQ.txt at master · jaakkopasanen/AutoEq
Automatic headphone equalization from frequency responses - AutoEq/Beyerdynamic DT 900 Pro X ParametricEQ.txt at master · jaakkopasanen/AutoEqgithub.com
yes, I was looking for the txt parametric EQ of the one below, because I don't know how to make txtIs this what you’re looking for?
I gave that to you in the second link in my post #13 above.yes, I was looking for the txt parametric EQ of the one below, because I don't know how to make txt
can you do it for me => file EQ below => txt
Ok thxJe vous l'ai donné dans le deuxième lien de mon post #13 ci-dessus.
