- Thread Starter
- #21
XLR, Sennheiser included the balnced XLR packaged and it fits int the hole of the THXWhat type of balanced jack your Senn 800s is using (xlr, 4.4mm, 2.5mm ... )?
Wow, how did I miss that? I am actually looking for a stand alone player at the moment but I just bought a dragonfly usb DAC to use with a raspberry Pi for my Haloween/Christmans light show. Looking at that I think I would have bought it instead. I think I could have made it work and the specs are awesome for the price. I'll keep that one in mind. I love my Topping D70, listening to it right now.Then you're better off using the nx4 dsd than the chord MOJO if you're going a stack route.
No reason to pay chord MOJO premium for the same performance as the nx4dsd.
Otherwise, I'd wait for amir to test a fiio m11, hiby r5, or Shanling m6.
Is it a different AMP? That is what I was hoping for. I will go look, but the pro is hard to find info on.Different amp modules for the M11 pro.
Also, the m11 pro isn't slow. It's the fastest dap out. It's just android, nothing klunky about it, unless you don't like Android.
I'd love to send amir daps to test, but I feel like he's so backed up I wouldn't be able to wait.
All is on the headfi forum. That's your best spot since it's where a rep interacts with a community in one dedicated thread.Is it a different AMP? That is what I was hoping for. I will go look, but the pro is hard to find info on.
Does the the PRO have a better processor as well? No info on the Fiio site.
Thanks Tential. I swear I searched for this on headfi but didn't get any hits. I guess I can just look through the forum.
Its all android, but some people do a better job of getting rid of cpu wasting stuff they don't need than others. CPU speed is a big one but the customizing of the Android OS and getting rid of unnecessary overhead is more important usually. There is just so much in there that is unnecessary for a a DAP.
Just like the DACs, the processor is only one chip, and how it is supported both with the quality of external components and design can make it either shine or suck but with a processor you have to consider the os programming as well.
I have no problem with THX chips, but you have to consider the design. Just like the ESS THD Hump, the design can exacerbate a problem or eliminate it. I would put the THX AAA 789 amp I got from massdrop up against pretty much any piece of audio equipment I have ever owned. Not for power but clarity and S/N ratio. Not only is it dead quiet when there isn't anything to listen to, it just makes everything I hook to it shine (headphones and IEMS) and I listen to it every day. I am still a huge power amp guy but it isn't practical with neighbors to drive thousands of watts a channel at 3AM when I spend a lot of time working. Other than that wonderful vibration of all your internal organs the THX and headphones, whether open or IEMs, give that sound I love. Amazingly my hearing is still pretty much intact.
Anyway, its all in the design. A lot of people from A&K to Fiio are using the same chips at vastly different price points. I think after all these dicsussions I am ready to buy a M11 Pro, was just hoping Ebay would send me one of those 10% off coupons they send me every few weeks as people are pretty firm on the price of these for now. I am very grateful for all this information as well as the pointer to the NX4. Thanks so much.
Once I get it I am going to put it side by site with the A&K with a blind sound test with a few audiophile friends. I think it will hold its own., but either way I will let everyone know. I agree it would be fantastic to have Amir evaluate and rank these as he has with the DAC list, but DAPs are a little more complicated to evaluate and I agree he is already overloaded. I will let you know my own subjective but as honest as possible results.
To add to this, I think it comes from people using smartphones from Samsung and the bloatware from those types of manufacturers. But we're talking open android, so it's already removed most bloatware.
When someone says "optimized" but can't tell you the exact lines of code they altered, and the exact performance benefits, that's when you know you're being fed marketing bs.
Similar to how fiio has a "pure music mode" you'll see audiophiles insist there must be a reason why the mode is there, and it MUST improve audio quality, but they will not bother to give any technical reason why. Just the most bland "optimize" type junk comment.
I mean, this even digs into soc/processor construction. On non node shrink years, they'll give you a ton of marketing bs, but usually, you can not optimize a cpu architecture much once it's done other than eek out a other 5-10% performance. The type of performance difference you're implying is essentially what amounts to a node shrink level of performance difference, which just can't be achieved by software. Hell, if you could, amd wouldn't have been screwed for years and could have just optimized the software for their bulldozer level cpus.... But again, you just can't optimize software for those types of performance differences beyond super niche instances.
What about this versatile portable player?
https://www.audiosciencereview.com/...o-measurement-of-lg-g7-thinq-smartphone.4468/
And by the way I agree with pretty much everything in this post. it popped up after I put my last reply in. Yes, trying to sort out marketing BS from fact is while we are all here. I am not trying to perpetuate any incorrect myths, I'm actually trying to sort facts from fiction out a lot of the information I see which is substantial. If I knew everything I wouldn't need to post here.
And yes, you can usually only do better than the OS if you have a special limited case where you have tight control over the data as opposed to the more general case the OS is made for. On the other hand, improvements in small bits of code that are hit frequently can have substantial impact on overall performance. Do these people really do that? Not sure without measuring every DAP out there, but it is certainly possible as a DAP is a very limited case. I agree that not saying exactly what they have improved makes me skeptical as well. Modifying an OS also can lead to issues down the road with adopting new features so it certainly better be worth it.
Have you used your R3 and the ipod touch, with the r3. Receiving through airplay? This works with a lot new daps. Almost any newer one. You could essentially use airplay(on any ipod. Touch or iPhone) to your dap to wirelessly and losslessly listen to high-quality music through many devices. It's an interesting use case anyway. You can also airplay things to a dap from macos device to watch a movie wirelessly with headphones. Just things to jog your imagination of the fun with airplay if you hadn't thought about it yet.putting either a HiBy R3 or iPod touch together with a Mojo has been a portable solution that allows me to drive all my headphones on the road. Of course if I'm just using IEMs or Grados, I can just drive them from the portable player alone, and not notice any difference. It only seems to matter for either high impedance Beyers or Senns, or planars (HE560 needing the most juice out of things I have)
The R3->Mojo is the most compact stack I could find, connected with coaxial. The iPod touch has the advantage of being able to run a fair number of streaming apps that the R3 can't do. I could of course use an iPhone with the Mojo, but when they're stacked together with Wifi/LTE/etc turned on, I can hear RF interference bleeding into the Mojo. So the iPod touch wins, just using Wifi to download stuff, and then going to airplane mode.
I did try for a bit using the HiBy link app on my phone to connect/control the R3/mojo combo, but it was kind of buggy. I recently updated the R3 firmware and might give it another shot.Have you used your R3 and the ipod touch, with the r3. Receiving through airplay? This works with a lot new daps. Almost any newer one. You could essentially use airplay(on any ipod. Touch or iPhone) to your dap to wirelessly and losslessly listen to high-quality music through many devices. It's an interesting use case anyway. You can also airplay things to a dap from macos device to watch a movie wirelessly with headphones. Just things to jog your imagination of the fun with airplay if you hadn't thought about it yet.
All of the benches for all the daps are out there and all of the user experience corresponds. It's not hard to find them all. That's the point, I've already done that legwork for you. I've gathered that data too many times to count and it's a hard post to put together. And I don't want to make this too long this time lol.
The end conclusion is the same. You really do want the fiio m11 if you don't need Google play. You pay ~$400, same as the other daps, and get an soc that's far superior. It's one with big cores, like your current smartphone, vs little cores like the background cores on your smartphone for multi tasking. Those little cores make the cpus of hiby, and Shanling daps. There's an actual reason behind the fiio m11 user experience. This is a science forum... Are you seriously surprised that better socs performed better? Lol.
I've wanted a dap for years but the industry didn't want to make a device with performance specs I'd use, on the android platform, while getting around android src.
I have messaged every manufacturer multiple times to start using socs like the hiby but Better, and I've bugged hiby about lte access.
I'm a patient fellow so I'm happy using my es100, and now they've all hopped on except Ibasso, but I have options so they can enjoy losing sales. And hiby announced lte access.
So I care because I've invested time actually asking them for this. Because I don't think the SoC in previous daps costing $600+ was acceptable and I'd rather message a manufacturer for what I want, than just capitulate and give them money unless the device is actually good.
So far, I was wrong about the fiio m11 (on basically everything long other story) and it's good in every regard if you don't need Google play.
From all of the scientific knowledge we know about the daps. Until someone reputable provides other data (there's a chart showing all these daps Snr, amp power etc. From someone in China but who knows who reputable that is), the fiio is your best bet because we can't logically conclude any of these daps have any significant sound performance difference. But we can easily conclude fiio is giving you a large amount more of soc performance (and a more modern soc design, the snapdragon is on 28nm vs the Exynos used here on like 14nm process) I mean... It's a steal. The rep didn't understand dta, and said they bypassed the src, but then said something to the effect to make me believe they hadn't. So I had disregarded the product. I must have misunderstood, because they do say it right on their site. So I hope it does.
This is why I want to send amir an m11. And maybe someone can buy a worse dap soc and send that in, so they can deal with the crappy user experience, and we can see if there is a significant scientific difference. I was not impressed by the Ibasso dap review on here.
That's using the phone as a remote.I did try for a bit using the HiBy link app on my phone to connect/control the R3/mojo combo, but it was kind of buggy. I recently updated the R3 firmware and might give it another shot.
Yeah, from all the objective data it seems the M11 is the best value. I can't deny the smooth sound of the A&K, but I think that is more in the analog section than the DACS. I just can't justify the price of the A&Ks for the objective data. Until you have an objective app you can put on the the DAPs I am skeptical of all the benchmarks for the soc because they are too easy to skew if you know what you are trying to make measure well.All of the benches for all the daps are out there and all of the user experience corresponds. It's not hard to find them all. That's the point, I've already done that legwork for you. I've gathered that data too many times to count and it's a hard post to put together. And I don't want to make this too long this time lol.
