Sending balanced signal to unbalanced subwoofer
starfly
I ordered a Minidsp Flex, the balanced version (found it for less than the unbalanced version because of all the tariffs), to be used in a 2.2 setup.
My main speakers are driven by a purifi amp with balanced inputs, so those will be fine. But my 2 subs only have unbalanced inputs. Will the 4vrms output of the Flex cause issues for the subs? Will be using TRS > RCA cables.
This from the miniDSP support portal should answer your question. Since the recommended cable is using only one of the 2 branches of the balanced output, the voltage as received by the RCA input will be reduced by half to 2 V.
Now if I could only find such a cable somewhere. The article only references the type of cable to be used. Will look into it.
You can order custom cables in USA from Performance Audio (and several others places). I started down the path of doing my own wiring, and then realized I would have been far ahead just ordering custom from them instead.
If looking for pre-made cables, be sure they use 2-wire STP (single twisted pair) rather than coax cable. And that the wring exactly matches this diagram.
Good call. I also made my own cables in the past, and overall it's just way cheaper (and probably better soldering lol) to have a company like this do it. But perhaps less fun :)
Yep. The markup by Performance Audio is way below the value of my time spent making cables. That might be different from someone who makes cables all the time; but I only do it on a few occasions.
I was also impressed with the range of connector and wire options they provide, including all of the components I decided were the ones I wanted to use on my interconnects.
I have made my own. Used one leg and ground and also both legs and no ground. Gain was high with both legs and no ground.
Since your dac has 1/4” connections just use a TR plug and a RCA. TR plug into a TRS jack is single ended. Buy one TR to RCA if you do not want to make one.
Which is different from the specific cabling guidance from the manufacturer, which shows leaving Ring unconnected.
Their recommendation is highly questionable. While it is really important to leave the R contact of the TRS unconnected it is also important to make the ground connection as low impedance as possible and for that you have to connect the shield on both ends, notably if the cable is long. Otherwise increased hum levels may result.
... but shorts out half of the driving circuit which has to be avoided as degradation and even damage may result.
Using T and R but no GND may work but is not best practice. Depending on the grounding scheme of the devices, this can still short out the Ring signal or even destroy the driver circuit.
What I did (for two subs) is to buy a long trs to trs cable from amazon, cut it in the middle and solder RCA connectors leaving ring floating. It was the most cost effective solution I could think of. It works fine, but there are pops if I switch off the DAC (Motu interface) before the subs. Asked Motu about this and they rightly pointed out to the trs > RCA solution was not ideal. But other than transforming the amp inputs to balanced, I don't know anything better.
So what would be best in your opinion?
TRS-Plug with R not connected, then going to a good (low shield resistance) standard coaxial interconnect with RCA on the other end.
Alright, I'm gonna build my own cable I guess, just ordered all the parts. So how should I be soldering this exactly on the TRS side? Do you happen to have a resource with a diagram?
https://www.ranecommercial.com/legacy/note110.html, Figure 9, just that the right side is an RCA instead of TS.
Simplest way to do this -- as others have mentioned -- is to buy a longer RCA--RCA cable, cut it in the middle and solder TRS plugs to the open ends,, leaving R unconnected.
I am also considering the flex balanced version since my amplifier has xlr balanced input but I would like to also use my avr sub rca preout to the input of the flex for multi sub integration.
I saw that minidsp do not recomment an rca to trs cable for the inputs because of a 15dB sinad drop. What would you suggest in this case? How much does sinad matter for the subwoofer signal?
@starfly what do you use as a source to the flex input btw?
I'm using a RaspberryPi with a I2S DAC that has a balanced output. I also have tried connecting directly to RPi with USB.
Currently I'm not using it at all though. I need to find time to do some measurements for different loudness targets and create 4 presets on the minidsp, each for different listening levels. I'm just not overall satisfied with the bass levels it produces at lower listening levels (which is usually how I listen). That's one are where my Denon AVR excels with DynamicEQ. It just always produces a nice deep bass at lower volumes. Wish the miniDSP had built-in loudness compensation, but it doesn't.
Yeah it will be worth doing that. DEQ increases the treble which I am not a fan of.
When I EQ'd my subwoofers on my Marantz AVR using MultiEQX and Magic Beans, to me the bass was improved at all volumes.
Reactions: CK.
sub eq will improve the performance in general compared to non eq. Not sure how magic beans can improve subwoofer responce though if you already have MEQX
