TimW
Happy to help
Definitely go with DSP in some form. Regardless of how well the speaker performs, the sound will be affected by the room. The affect is especially prominent in the bass region which is why multiple subwoofers and room correction are commonly used to get even bass in a room. This requires a device with DSP and a microphone. Also you will want a crossover between the subwoofer and main speakers to get proper summation between them. This crossover relieves the main monitors of playing deep bass so they distort less and can play a bit louder. The crossovers can be done in a powered subwoofer like the JBL LSR310S, Kali WS-12 or the Adam T10S. These subs are designed for use specifically with their corresponding studio monitors so they have inputs, outputs, and crossovers built in. If you look at higher end studio monitor options from the likes of Neumann or Genelec, they even have options for room correction using their own built in DSP.
Check out measurements of the Adam T5V done by Amir, he also measured the T8V but not the T7V. He specifically states that compared to the LP-6, Version 1 that is, the T5V can get louder with better bass. Also said the noise wasn't an issue for him. However the T5V does have a major flaw in frequency response in the high frequencies, so you would definitely want a DSP to correct the response there. Every speaker has its flaws.
If you really want to go loud but don't want to spend big money, take a look at the Behringer Truth B2031A. It has a 8.75" woofer, 265 watts of amplification built in and a claimed maximum SPL of 116 dB @ 1 Meter. Not as smooth in frequency response as the other options but maybe someday there will be PEQ filters available to smooth that out.
If you live near a Guitar Center they have most of these popular models on display and powered on for listening.
