Backing up HDCD to music server
r042wal
Ontario (Canada)
I would like to rip an HDCD and add it to my Aurender music server. Since the format is not the same as SACD, can I just use DBpoweramp? I don't want any compression so thought maybe a WAV file might be the way to go. Thanks for any comments.
HoweSound
BC, Canada
I have a few HDCD disks. My understanding is that you need an HDCD enabled player to play the encoded disk. Without an HDCD player it just plays as a standard CD. My Denon universal disk player has a visual indicator light when it is playing an HDCD disk. I haven't tried playing a copied HDCD disk to see if the encoding is preserved on the copy.
DVDdoug
I don't know how to rip an HDCD...
WAV is probably the worst format for metadata/tagging. It's not well standardized or widely supported. FLAC (lossless compression) is better... Any of the standard compression formats are better for metadata.
And as a bonus, your files are almost half the size. I think decoded HDCD requires 18-bits so you'd need 24-bit WAVs which are 50% larger than "CD quality" WAVs. FLAC is "smart enough" not to waste space on unused bits so the FLAC might be less than half the size of the 24-bit WAV.
However FLAC is not quite as "universal" as WAV or MP3 and some hardware players can't play it. (Not a problem on a computer or smart phone.)
r042wal
r042wal
Ontario (Canada)
I plug a CD-ROM into my laptop. I want to rip the HDCD then copy it to my Aurender server. Size of the file is not an object because storage is cheap.
I normally use DBPoweramp and notice they have HDCD support built in. Foobar2000 add-on just seems to support 32-bit architecture. I am waiting on the delivery of the CD but will give Poweramp a try, FLAC with no compression and see what happens. Comments folks? TIA
Destroid
Foobar2000 is a 32bit Windows app and will work fine. It is the Swiss Army knife of players/processing with plugins. SACD, HDCD, and every file format works.
Guermantes
Brisbane, Australia
r042wal
r042wal
Ontario (Canada)
The add-on HDCD option will not install because of my 64-bit architecture
r042wal
r042wal
Ontario (Canada)
What is the CD? Is it in this list? If so, it will tell whether peak extension or filters have been used when it was encoded.
DBPoweramp will autodetect HDCD and you can set it to decode and convert to 24 bit 44.1 kHz where applicable (capturing any peak extension benefits).
It's Joe Walsh'e second studio album and not in the list. Maybe because it is a MoFi remaster?
Guermantes
Brisbane, Australia
I'd just let DBPoweramp do a conversion to 24 bit with the HDCD DSP feature enabled. Will it give you a report as to whether peak extend was used? Some HDCDs are flagged as such simply because the mastering engineer used the Pacific Microsonics hardware even if no extension or filtering features were used.
Here is a GIF that shows waveforms for an HDCD (Tubular Bells) that has been ripped to WAV first without conversion and then subsequently decoded to 24 bit with Foobar2000's HDCD DSP. You can see that this particular CD has some peak extension happening:
tmtomh
I could be mistaken, but I'm pretty sure that MoFi has never produced an HDCD encoded title.
As for ripping an HDCD, as others have said, the ripping is easy, because it rips like any other CD.
Before trying to do anything further with a ripped HDCD, I would first check online as noted above, to see if that particular HDCD uses Peak Extend or Low Level Range Extend. If it uses neither of those two optional HDCD features, then IMHO there's nothing to be gained sonically in decoding it - just play the regular CD rip you did of it.
If it does use Peak Extend and/or Low Level Range Extend, then you can use Foobar or DBPoweramp as noted above.
My understanding is that the HDCD data itself decodes to 20 bits and Foobar (and therefore I assume also DBPoweramp) pads that with 4 bits of zeros to make a standard 24 bit file.
r042wal
r042wal
Ontario (Canada)
OK thanks. I ordered the CD from GB and am awaiting the arrival. I have been going off the description on DisCogs. Thanks for all the help
JamesYeomans
Timcognito
NorCal
Thanks for all the suggestions. I am waiting for the the CD to arrive and will follow up. Any preference over Foobar2000 and DBpoweramp?
Have not used Foobar since 2017, but a lot back then, and found dBPA just a better more focused tool for ripping getting most of 1000+ CDs done without issues. Foobar is (was) free and dBPA is $35.
