I have a Audiophonics HPA-S400ET and a HPA-T400ET in a 5.1 system. When warm if the amplifiers are turned off and then on the HPA-T400ET trips out. If you wait about 60 seconds, the amp starts up fine. They both use a Hypex SMPS1200 power supply. You can hear the relay on the SMPS turn on then off. J4 pin 10 on the SMPS is called DC Error and J3 pin 36 on the Purifi 1ET400A, SCL/Fatal or Amplifier error/fail.
Hpex state: -
In the event of a critical failure occurring in the connected amplifier, the SMPS1200 needs to be switched off rapidly. The SMPS1200 provides a single DC Error Input designated for UcD OEM/NCore series amplifiers. The DC Error Input is latched and will not auto-recover. To reset the DC Error the module must be disconnected from mains for at least 1 minute to allow the primary capacitors to drain.
Purifi state for DC Protection (DCP) :-
In HW Mode, DCP-latch-off condition asserts /FATAL signal low. It is recommended that the /FATAL signal is used to switch off the power supplies.
However, Purifi EVAL1 and 2 systems do not use this signal and do not connect to the SMPS J4 connector.
Audiophonics do use J4 and I think they use this error signal; however, I have no circuit diagram to prove this. In operation this is not a problem, once you know what is going on. Just wait and then turn it back on. I have not asked Audiophonics and cannot see any reference to this in their information.
I am very happy with the amplifier's performance.
I would like to know if anyone has come across this issue.
Hpex state: -
