Recently I read that this -60 dBFS DR measurement method is from AES17.
It is probably accurate enough for DAC output DR, but for amplifier, isn't the noise floor going up and down with the volume? Especially amp with analog volume control. So that means measuring noise floor at -60 dBFS and then add 60 dB to calculate the DR at maximum volume is not accurately reflecting the actual DR at maximum volume, because at max volume noise floor will be higher than at -60 dBFS. Is my understanding about this measurement correct?
Thanks!
The
volume in most amplifiers is usually an attenuator potentiometer on the input. The amplifier gain is fixed.
Look up one of the power amplifier reviews on this forum. What you see in figures of %THD+N vs power is that you have three regions:
- a region with mid level of THD+N gradually descending, dominated by noise;
- a region where the amp performance is optimal and the THD+N has a plateau on the minimum;
- max power: steep increase due to clipping.
In general I don't find the DR of a power amplifier to be a very useful metric, since it's related to its max power. As Amir does, THD+N measured around ~5W (normal operating conditions, but this depends on your listening level and speaker sensitivity) can be more representative of what matters in normal operating conditions.
Take my words with a grain of salt as I am self-taught on these topics
