Veri
- Joined
- Feb 6, 2018
- Messages
- 9,667
- Likes
- 12,308
Well, sure. Let's seeLets see what survives longer, the NFB-11.38 or D30 Pro
It measures within shouting distance of a number of modern modern solid state amplifiers! See: https://www.audiosciencereview.com/...review-and-measurements-of-dynaco-st-70.7224/I wonder how well a Dynaco ST70 would measure....people still love these amps.
Companies can build audio products out of anything they want. That is their concern, not ours. Ours (audiophiles) is to get a performant audio device. It is not like you are going to keep the top open and hang the thing on the wall and rave about all the parts. You listen to the thing. In case of Audio-gd products, they post measurements that are NOT representative of the product performance. Folks go by them and think they are getting something good with the explanation what you give: lots of parts so it must be good. Well, it is not. Spreading a design across large boards with tons of components with who knows what spec is a recipe for sub-optimal design. Again, if they can make it work, kudos to them. But they don't.Plenty of components in the box? Sure because he is not connected with commercial chip factories that will condense whole circuit boards into a single chip. That cost $$, eliminates component failure potential but also removes further tinkering with the circuits. Because you better be 100% sure that your circuit design is rock-solid, tested, tried repeatedly. Less noise/better measurements for sure.
They do make good business. Alas, in all the testing I have done, they only cost money but don't improve performance. Here is where one of their complete products ranks: https://www.audiosciencereview.com/...urson-soloist-3xp-review-headphone-amp.34353/BTW, Burson makes a good business out of "discrete op-amp design".
You have this completely backwards, a minute of digging would show how easily one can obtain the exact same DAC chips used in many high performing products. I don't know where you live, but I'd wager you yourself could you have thousands of them on your doorstep within a couple days. Fully discrete designs are going to be more expensive in most cases. It also seems strange to conclude that (by your admission) the DIY hobbyist is capable of engineering a discrete design that can compete with SOCs produced by actual R&D teams with millions in backing.Plenty of components in the box? Sure because he is not connected with commercial chip factories that will condense whole circuit boards into a single chip. That cost $$, eliminates component failure potential but also removes further tinkering with the circuits. Because you better be 100% sure that your circuit design is rock-solid, tested, tried repeatedly. Less noise/better measurements for sure.
Sorry, but that is wrong to begin with. Level-match has to be done in the analog domain, with a DMM to avoid unprecise and flawed matching.I volume matched the amps with my SPL meter and started to switch and listen.
If this wasn't done blind, not to mention randomised, then the "proper AB comparaison" is worthless.and started to switch and listen.
We do not, because this concept does not exist in any shape or form.so it is definatly burned in, if you believe in that.
ABX.for a proper A-B test session,
That CAN happen with a poorly designed headphone amp. Especially if the output impedance of the headphone amp is not low relative to the headphone impedance.* Headphone impedance (and speaker impedance) is not flat across the frequency range. If the amplifier's output impedance is too high, these variations get translated into frequency response variations... If the impedance has a bump-up in the bass range, the bass will be bumped-up etc. We DON'T want to "match" the impedance!Synergy with your gear trumps everything...
...My two favourite closed backs want different sources as they kind of enhance the traits of each headphones and they are kind of yin and yang though still relatively neutral compared to what is out there.
Thank youWelcome !
The level matching was done with a good old analog sound pressure level meter. It was fixed between the earpads and never moved while I adjusted the volume of the amps. With the pot meter on the Audio GD, the match was perfect on the meter.Sorry, but that is wrong to begin with. Level-match has to be done in the analog domain, with a DMM to avoid unprecise and flawed matching.
I was not looking for a blind test, I cannot do that by my self. I was looking to se how much better the SMSL was. Considering the 11 years of DAC and amp improvements and the great meassurements of the SMSL and I had even watched a number of rave reviews on youtube, praising the SMSL. I had absolutely no doubt that the SMSL was totally superior, that is why I bought it. So confirmation bias was very solidly on the side of the SMSL.If this wasn't done blind, not to mention randomised, then the "proper AB comparaison" is worthless.![]()
Thank god! I totally agree with that. I have heard speakers and headphones change slightly as the drivers breaks in with in the first hours, but never with solid state electronics.We do not, because this concept does not exist in any shape or form.
That is good points you make. The next time I get bored, I might just A-B my other cans alsoSynergy with your gear trumps everything. There is so many Amps that has low enough distortion and other technicalities it dont matter as much. But every headphones on earth is a coloured compromise and has to be
Thank you
Without proper level matching and blinding you cannot find out how much better the SMSL is (or is not).I was not looking for a blind test, I cannot do that by my self. I was looking to se how much better the SMSL was. .
I am completely aware of how much bias can mean. My bias was completely and fully on the side of the SMSL. It is 11 years younger, has a great NEW DAC, has rave reviews and meassures near perfectly, as I read on this website. I thouroughly absorbed ALL this information before purchasing the unit. I was honestly flabbergasted by the results I got.I was a/b-ing for fun with my original focal utopias connected to an smsl raw mda1 to my pc. My pc also has a digital out dongle to neumann kh150 monitors. All three have good reviews here, sounds excellent and at one point I forgot I had switched to the headphones instead of my speakers!
This isn’t me saying good objective scores mean good sound but more towards me saying that we can be easily biased.
