Specifications
Microphone preamplifier
MIC GAIN: | 0 to +60 dB |
LINE GAIN: | -10 to +50 dB |
PHANTOM POWER: | 48v +/-4v @ 10mA/Channel (12VDC only) |
MIC EIN: | -126dBu |
CMRR: | >80dB @ 1kHz |
MAXIMUM INPUT LEVEL: | +18 dBu |
INPUT IMPEDANCE (Mic): | 3k Ω balanced |
INPUT IMPEDANCE (Line): | 10k Ω balanced |
FREQUENCY RESPONSE: | ±0.5 dB 10Hz to 65kHz |
CROSSTALK: | <-90 dBu @ 1kHz & 10kHz |
THD+N @ 0dBu (1kHz): | 0.003% (-96dBu) |
SNR: | 96dB |
XLR: | Pin 2 (Hot), Pin 3 (Cold) & Pin 1 (Shield) |
1/4” TRS JACK: | TIP (Hot), RING (Cold) & SLEEVE (Shield) |
D.I / Instrument Input (Channel 1):
D.I GAIN: | 0 to +60 dB |
MAXIMUM INPUT LEVEL: | +10dBu |
INPUT IMPEDANCE: | 1MegΩ Unbalanced |
FREQUENCY RESPONSE: | ±0.5 dB 10Hz to 50kHz |
THD+N @ 0dBu (1kHz): | <0.3% |
SNR: | 95dB A-weighted |
1/4” JACK: | Tip (Hot) & Sleeve (Shield) |
Analogue to Digital Converter (ADC 1 & 2):
(Measured via Insert Returns under AES-17)
MAXIMUM INPUT LEVEL: | +18 dBu (0 dBFS digital maximum) |
DIGITAL REFERENCE LEVEL: | +18 dBu = 0 dBFS |
INPUT IMPEDANCE: | >10k Ω Balanced |
CROSSTALK: | -115 dBu @ 1kHz & 10kHz |
FREQUENCY RESPONSE: | ±0.5 dB 10Hz to Fs/2 (Nyquist) |
CROSSTALK: | -115dBu @ 1kHz & 10kHz |
THD+N @ -1dBFS (1kHz): | <0.0003% (-112dB) |
DYNAMIC RANGE: | 120 dB A-weighted |
Digital to Analogue Converter (DAC 1 & 2):
(Measured under AES-17 at line outputs 1 & 2)
OUTPUT IMPEDANCE: | <100 Ω |
CROSSTALK: | <-118 dBu @ 1kHz & 10kHz |
THD+N @ -1dBFS (1kHz): | <0.0006% (-104dB) |
DYNAMIC RANGE: | 124 dB un-weighted, 126 dB A-weighted |
Headphone Outputs:
(Measured under AES-17 at phones output)
MAXIMUM OUTPUT LEVEL: | +14 dBu (0 dBFS digital maximum) |
DIGITAL REFERENCE LEVEL: | +14 dBu = 0 dBFS |
OUTPUT IMPEDANCE: | <50 Ω unbalanced |
CROSSTALK: | <-110 dBu @ 1kHz & 10kHz |
FREQUENCY RESPONSE: | ±0.5dB 10Hz to Fs/2 |
THD+N @ -1dBFS (1kHz): | <0.0008% (-103 dB) |
DYNAMIC RANGE: | 121 dB un-weighted, 124 dB A-weighted |
MAX LEVEL INTO 30ohms: | +10.2 dBu 0.002% THD+N Power: 210mW |
MAX LEVEL INTO 60ohms: | +14.2 dBu 0.001% THD+N Power: 54mW |
MAX LEVEL INTO 600ohms: | +14.2 dBu 0.001% THD+N Power: 54mW |
1/4” JACK: | TIP (Hot), RING (Cold) & SLEEVE (Shield) |
Digital Input:
ADAT 16 CHANNELS: | 44.1kHz to 48.0kHz |
ADAT 8 CHANNELS (SMUX): | 88.2kHz to 96.0kHz |
STEREO S/PDIF: | 44.1kHz to 96.0kHz |
USB2.0 High Speed:
No. of INPUT CHANNELS 20: | 20 (4 Analogue, 16 Digital) |
No. of OUTPUT CHANNELS 24: | 24 (8 Analogue, 16 Digital) |
Connector: | USB Type-C |
Included Cables: | 1.5m USB 2.0 Type-C to USB Type-C, 1.5m USB 2.0 Type-C to USB Type-A |
DSP Mixer Latency – ROUND TRIP (in-to-out):
44.1kHz | 0.677ms |
48.0kHz | 0.625ms |
88.2kHz | 0.354ms |
96.0kHz | 0.323ms |
Dimensions:
Unit: 276mm (w) x 51mm (h) x 174mm (d)
