dasdoing
oh yes, it is importand to emphasize that "linear phase" correcting software actualy uses mixed phase
I agree, but it’s important to note that (especially for bass) preringing is much more audible than postringing, which is a “natural” phenomenon and very well masked. I do have a crossover phase linearization filter in my system for the 2 kHz woofer/tweeter crossover which subjectively provides good results. At such a high frequency it would be extremely difficult to hear preringing for such a smooth filter.as always with audio, it's a compromise where you have to find the right point in the middle.
same is for pre-ringing and (to put it into perspective I will call it) pos-ringing.
This isn’t because of excess phase correction in the bass region though, right? I’d guess most of this is due to correcting any L/R frequency response imbalances.personaly when I compare (listening) FIR room correction (actualy mixed phase) filters to filters created with REW in my system there is dozen times bigger impact on center clarity then audible delay. as Bob Katz describes it (he uses Acourate): The diference is like 3D vs 2D. I have seen other describe this as "lost wideness"; this is not the case, the mid signal is more centered (as it was supoused to be), not the side signal
I didn’t have nearly as good of a result linearizing the 80 Hz subwoofer/speaker crossover... The difference was very audible with kick drums and the bass certainly seemed tighter, but at times I felt like I heard the bass of the kicks starting very slightly before the rest of it. But I guess this depends on personal preference and the range of positions you listen to your system in.
Yeah, I also found my speakers to subjectively sound “deeper” with the woofer/tweeter crossover phase linearization.yea, when you hear it it sounds very bad. "pos-ringing" on the other hand will always be masked by other sounds, plus we are used to it.
I can only hear the improvement in group delay when directly comparing (as you say: tighter kick). we can say that this is something you don't need, but if you invest the time you will have improvement
though the bass correction obviously doesn't impact this in the overall image (the bass sure get's centered, too) it is the result of phase correction. there is no big diference in center clarity before and after REW correction, but there is a gigantic diference after FIR correcting; it actualy sounds like if speaker were changed. the image also seams "deeper". the sound seams to have a space instead of a "wall of sound" generated between your speakers.
But with regards to your comment about the center becoming sharper... did your REW and FIR filters have the exact same frequency response or were they different?
From you guys talk correcting phase can only correct on axis but not off axis? Why is that possible if phase is just timing?
they are indeed different. it is not possible to match the correction with REW with it's limitation to 20 eq filters. I could actualy compare this better with my software (https://www.ohl.to/about-audio/audio-softwares/align2) since it can generate minimum phase correction too. got me curious, will do this after the gym
So I just compared.
ignoring a small variation above 14Khz the FR responses match
(var-smoothing > right channel above, left below)
they do sound TOTALY diferent though in terms of center image. the MP corrected one is much more spreaded.
this is the right channel after MP correction. in black the exess phase
this is the right channel after LP correction. if you ignore the vertical jumps caused by dips it is close to linear phase (I am sure I can still improve this. I aplied delay to the mains, which I should "delegate" to the FIR correction, too)
as soons as you move the mic/head the relation of delay of direct and reflected sound will change.
following image is an example of a speaker but it explains it in the room, too.
Could you please put the FR on a 50dB vertical scale pls?
I could actualy try to make this diference audible to you guys on a headphone by convolving music with my room IRs and the filters. not sure how this will sound on headphones though
like this? the diference is very minimal; ignoring above 14khz which shouldn make a diference
That would be interesting, thanks.
I guess it depends how you define minimal The differences in amplitude there look greater than established audibility thresholds (would be clearer if you lined the graphs up directly over each other).
The phase graphs look pretty weird to me, TBH. Would you mind trying two things?
- Put some smoothing in place so that all the narrow peaks and dips in the FR disappear.
- Unwrap the phase.
perhaps using trace arithmetic (a/b) to show the diff would be even more evidentYou were 100% right that the amplitude responses were very similar
They both look very similar to me in terms of group delay TBH.
There's some weirdness in the high frequencies decay which can be seen in the GD, decay, and fourier views for both minimum phase and linear phase responses.
Clarity traces are slightly improved with linear phase, but again, not that much of a difference.
That looks very different to mine! Now I'm wondering if I've used incorrect settings in REW (not a piece of software I normally use). Which program have you used there to generate those graphs?
