I must say that Miraval Studios is a really great-looking studio, I'm sure that Atmos sound system with all those ATC speakers sounds great.
Interested as well.Has anyone heard the new Mark 2 25a?
I would not be able to make anything here, that is the most sterile place I've ever seen.
I find your assumptions a bit strange as you hardly can know that before you are sitting by their console, if it sounds really good in that room it may be all that is needed to find the inspiration you need.
Reports are it's a little more even handed and a bit cleaner in the top end. The original 25A is definitely a bit rolled-off sounding in the top end and the overall response in the tweeter range was perhaps a bit "grungier" than desired, the new ones supposedly are better in both regards. This I'd believe, given the cheap Peerless tweeter in the original not being what I would call "particularly good" in response.Interested as well.
Unfortunately the measurements are pretty worthless since they were done in a small room. You can see the horizontal error at the tweeter/mid cross, but it's surprisingly minor for a flat baffle speaker.A new review of the SCM100ASLT, with measurements:
https://hometheaterhifi.com/reviews/speaker/floor-standing/atc-scm100aslt-active-loudspeaker-review/
in room measurements are not that worthless, for example you can see there is a huge roll off at 20hz. The big boy is tunned pretty high for its size, that would explain models like thisUnfortunately the measurements are pretty worthless since they were done in a small room.
List price in Germany is 28.500 EUR per pair. I think it's too expensive. OK you have to pay extra for the "magic marketing dome"...A new review of the SCM100ASLT, with measurements:
Well, this "magic dome" is still one of the lowest distorting, wide dispersion midrange driver for home/hifi/studio usage at any price. Of course there is a similar dome from Volt, but that doesn't completely reach the performance of the ATC unit, according to the reports of many DIY-ers.List price in Germany is 28.500 EUR per pair. I think it's too expensive. OK you have to pay extra for the "magic marketing dome"...
The Volt dome is not similar at all. The ATC is underhung and has a double suspension, it can go way way lower than most dome mids without distortion going through the roof.Well, this "magic dome" is still one of the lowest distorting, wide dispersion midrange driver for home/hifi/studio usage at any price. Of course there is a similar dome from Volt, but that doesn't completely reach the performance of the ATC unit, according to the reports of many DIY-ers.
But yeah, their prices are very steep indeed.
Where are the data that support this statement?Well, this "magic dome" is still one of the lowest distorting, wide dispersion midrange driver for home/hifi/studio usage at any price.
1) Where's your scientific data?Where are the data that support this statement?
P.S.
I have owned a pair of ATCs with this marketing dome and did not find it convincing at all.
P.S.
