@Doodski and
@AnalogSteph thank you both for mentioning fan
frequency - something I omitted but suppose cannot be fully teased apart from dB - when it comes to fan size x “irritation factor”.
The only noticeable member in my stable is a Quadro P2200 GPU. I haven’t devised a custom solution and aftermarket options are not reali$tic, in part because it’s still very low on the noticeable-becomes-distracting meter.
It seems the (limited) feedback trend so far is as expected:
Fans are a practical - though not universal - necessity for off-the-shelf [multi-disk RAID-friendly] NAS systems and also multipurpose computers with crunch power.
For kit restricted to streaming / transport duties, fans are usually absent.
Not much heat = nothing to actively treat, eh?
I agree that case fans in rigs that aren’t doing intensive tasks probably won’t be noticeable in many average noise floor situations, but I also get why this would
feel acoustically unattractive in servers that sit with the rest of one’s stereo kit, or
be acoustically unattractive in servers that are very near a listening position.
My stereo setup has no specific “MLP” in a fairly spacious room. Although I do not have an extra room from which an expansive server can operate, it’s not noticeable (at least audibly) in the “music room.”
Ironic that
my server doesn’t actually serve
my music for playback, eh!?
It’s for movies / tv PLEX. Remote friends/fam can also use it for the many TB’s of music it holds, but my own stereo draws from a separate, fan-less dedicated setup with the same music data. I don’t prefer the PLEX interface for music, and I don’t mind data redundancy.
A little bit of airflow goes a very long way.
Sort of in line with what
@digitalfrost said, in my server’s case a
lot of airflow need go only a little way. Instead of moving a small amount of air suddenly and quickly, it moves a lot of air slowly and continuously. I picked my chassis based on (1) how many HDD’s I could modify it to hold and (2) how much air
inflow it permits (both sides have a
lotta mesh). All intake is passive, accelerated by 4x 120mm exhaust fans (secured with aforementioned rubber fasteners) that needn’t high rpm’s. An additional 2x 140mm low rpm CPU fans and 1 that never spins inside the PSU round out the mix. Well, those and the Quadro’s little whirlybird.
You can make your life much much easier if you have silent slow running fans.
I agree, even though my own at-this-moment stereo server->transport-> chain has no fans whatsoever.
Operation is basic, access purely local; there are as many limitations as there are advantages, but I’m enjoying fiddling with it for now.
For a larger server with double- or triple- (or… or…) digit TB’s of spinning storage, however, the rationale in passive cooling is (IMO) fleeting at best.
