- Joined
- Jun 19, 2018
- Messages
- 6,652
- Likes
- 9,530
Oh I just referenced NL because of Bruno/Hypex. Very interesting note about German custom--I'm now quite curious to ask my German colleagues about it!
Would be interested to hear what they say
And using better quality capacitors...
This picture on their website shows Panasonic capacitors. It may be a very early version. I'm pretty sure the unit I saw I had Rubycon on the amp board.
https://purifi-audio.com/eigentakt/
The SMPS had rubbish caps on it however.
From the little I know, the Dutch situation is similar. It is also in the interest of the employer: incentives are a real incentive.ot sure if it's the same in NL, although I'd expect it to be similar.
Is it just me, or do the connections and connector from amp board to speaker terminals look a bit under-sized for the average audiophile?
Ah that makes a lot more sense.Ok, after some further research, I've clarified the situation in Germany somewhat. Legal title to the invention generally vests in the employer, but a statutory scheme (aims to) ensure that the inventor also receives a share of the profits flowing from the invention.
Minor technicality: though the correct inventors need to be named on the patent application, they need not be involved in the patenting, so to speak. In the USPTO, an applicant can declare an inventor is uncooperative and consequently the applicant need not provide that inventor's signature on various forms. This can happen when an inventor-employee leaves the company and becomes unreachable.The employer can't patent something an employee did without the employee.
This guy, John Curl, did a video back in June on what makes a good amp. His main point is it's all about quality capacitors. I know nothing about them since it is not in my capacity to understand how they work::
I tested some caps in a piece of hifi equipment from the mid 70s just yesterday, the caps were all nippon chemicon ... and found that all the caps measured like new, seriously, . Didn't find a single bad cap, ..., no corrosion visible.
Could be a simple engineering decision. You don't put over specified and higher cost components in if the cheaper ones are perfectly adequate.
Not started my Purifi assembly yet, weather is still good enough here for mountainbiking ... ;-)
Purifi module:
Neurochrome buffer:
Hypex SMPS:
So just to be clear was the hypex failure the caps or something else?
So you have just demonstrated there is no issue then JohnThanks for those closeups, they identify the grade of Su'scon Hypex are using and the series of Rubycons Purifi are using.
The Su'scons are their HZ series. One step up from the bottom grade 105 degree caps. They are only a rated 3000hr cap. These are primary side (50/60Hz) filter caps for the bridge rectifier in the SMPS.
As discussed back in the thread, it is the internal I2R pwer losses (ripple current) that heat the capacitor internally and play a very significant role in premature failure. Su'son advise that a 5 degree internal temperature rise will halve their life. Coupled with localised heat sources from the heatsink and transformer in a compact form factor package, their life will be compromised.
The Rubycons in the Purifi are onboard local +/-V rail filtering/decoupling for the main rails. They are Rubycon ZL series. As the rated load life is a function of the ability to get rid of internal heat, the bigger the capacitor, the longer they last.
The ZL series have a load life of between 1000~5000hrs depending on package diameter. The 100V 100uF used on the Purifi board appear to be a 10x23mm package.
So, their rated load life is 4000hrs.
Caps do prematurely fail of course. This true of any brand. I have replaced my fair share over the years including "premium" brands. Amir showed a premium cap failure in his Mark Levinson dac earlier in the thread..Their remote diagnosis was cap, based on the symptoms. They seemed quite confident, given the symptom, and it made sense to me (my background is EE including analog and mixed signal electronics design). As I mentioned, they also zeroed in on the caps and had changed them in production, so there must have been an issue there
