Why would this be necessary?
Fiio responded:
Dear friend,
1. This plastic shield could keep the structure more stable. The K9Pro would not be damaged by the plastic shield under normal usage.
2. Though the radiating will be affected slightly, the K9Pro has temperature detecting and protection which could keep the K9Pro work in safe range. So please don't worry.
FiiO K9 Pro Hi-Fi DeskDop DAC&Bluetooth&Amplifier,XLR/RCA/4.4/Optical/Coaxial interface
If the LDAC color display is normal, the settings should be normal, you can enter the FiiO Control APP to see if the settings are correct? yes fiio control app looks everything fine. It also looks fine in music app under bluetooth connections or so. everything looks fine except that the k9pro...
www.head-fi.org
Fiio responded:
Dear friend,
@Vitaliy Belz I've been thinking about it for a long time myself. Especially if you put it on its side. In a good way, you need to measure the temperature of individual nodes and see their technical characteristics. I wouldn't be surprised if everything is within operating temperatures. It's...
www.head-fi.org
