Guddu
- Joined
- Feb 10, 2020
- Messages
- 1,560
- Likes
- 1,543
- Thread Starter
- #361
This is my first post and is perhaps a little tangential to the new unit but please bear with me!
I use two sources, from an MM phono preamp and from a Topping E30 DAC (used both for CD and streaming). I feed these to the preamp section of a NAD amplifier. From there they go to a miniDSP HD. The outputs from the miniDSP go to a pair of Aiyima A07 amps, one for each channel. The left/right sides of each amp are split into bass and mid/treble sections. Each amp feeds one of my my DIY hybrid open baffle bass distributed mode panel speakers. I have the volume maxed out on each of the A07s and use the NAD to control volume.
I've configured it this way to effectively bypass the volume pots on the A07s. However, it also means that the miniDSP has less signal to work with due to attenuation from the NAD.
Therefore, would it make more sense to replace the NAD (on long term loan from my son anyway) with e decent source switching box (I'll make it myself) and simply use the volume control on the A07s? Alternatively, would it be better to still max out the volume control on the A07s and put a passive preamp between the miniDSP and the A07s? I've already nailed together a passive preamp with twin stereo pots, but the DACT type pots are a bit unsubtle with small volume changes as they have too few steps.
In summary, what I'm essentially asking is whether a good passive preamp volume control pot and an effectively bypassed A07 volume pot is going to be better than simply using the A07 volume control? I'm thinking ALPS Blue Beauty log pots as a bare minimum and possibly a TKD four channel job to keep things neater.
Hi @simonhickie
Are you getting issues in your current setup as it is? or just looking to see it could be improved?
I am asking this because you probably have already done the best given the devices you have. Ideally minidsp should not have any issues working with input.
I am guessing you have minidsp 2x4HD? If Yes then you can input Phono pre-amp analog and digital inputs to minidsp directly, escaping E30, because eventually minidsp is acting as ADC and DAC in your chain before amplifier.
Is there any reason any you chose to use E30 here, asking to understand what benefit you might get like that.
